Since my original reply here:
http://www.endless-sphere.com/forums/viewtopic.php?p=531289#p531289
I have setup and tested the removable AmmoCan RC LiPo setup on both CrazyBike2 and the Fusin Test Bike. It would also work fine on DayGlo Avenger but has not yet been used there except for a test ride. This is a 7.62mm-type ammocan, and contains 14s2p, using four 6s and two 2s, which is perfect for at least 20 miles on the Fusin Test Bike, even hauling a trailer full of salvaged stuff in a headwind if I pedal, too.
A second similar but larger ammocan (50cal) is now mounted to CrazyBike2 with a larger pack to support it's 4KW+ burst mode and still have longer range.
Charging is just bulk charging, with occasional balance checks both when it is in discharged states and during charge and after full charge, and so far there are no unbalanced cells at any stage: all cells within a few hundredths of a volt of each other. Charger itself is a simple typical ebike charger, 4A max, from a clearance sale here on ES, and I think it was $10 shipped (I got two different ones for $20 shipped; the other was adjusted for the voltage CrazyBike2's pack is at). I didn't even ahve to adjust it's voltage, IIRC.
Arrival and test:
http://endless-sphere.com/forums/viewtopic.php?p=529334#p529334
Sale thread:
http://www.endless-sphere.com/forums/viewtopic.php?f=9&t=35270
http://www.endless-sphere.com/forums/viewtopic.php?f=9&t=35274
AmmoCan Pack post with more pics:
http://www.endless-sphere.com/forums/viewtopic.php?p=536242#p536242
and a pic of it's guts:
Fusin Test Bike thread with more pics:
http://endless-sphere.com/forums/viewtopic.php?f=4&t=39877
and a pic of the whole bike (which has changed a little but not much since this pic, mostly adding much better lighting):
and a pic of how the green pallet-straps (salvaged from stuff tossed at work) hold it on the rear rack (which works ok, has had no problems, but would much rather have it in the frame or on the front of the headtube, if I could mount it there).
It is held from sliding aroudn by 4 velcro strips, fuzzy on the pack and hook on the rack:
And a pic of it mounted on CrazyBike2, in the formerly open center section:
http://endless-sphere.com/forums/viewtopic.php?p=536248#p536248
Mounted on DayGlo Avenger for testing:
Would've been much better if mounted to the side of the rack support, down low at axle height, but I've had way bigger/heavier loads on that rack that caused me much worse riding issues. :lol:
