Hello guys,
i've stumbled across this board while searching for potential solutions for a special project. So far i've already collected some tips, did some calculations and made a generall plan. But before ordering components i wanted to collect some opinions on the choosen parts and my thoughts so far.
So first of all a general project description. The vehicle i want to electrify can be seen below:
It's a 6 seater bike with no connected rear axle, each wheel is driven separately by three of the passengers.
The bike was not designed for driving uphill which is why there is now a need for a conversion, as there are a lot of hills around here
It should be possible to drive the bike completely electric so there will be a lot of power required. I'm calculating with a combined end wheight with passengers of around 800kg.
Now my idea is to connect each separate axle (each wheel on the rear has one, they are just not connected in the middle) with an electric motor.
So some key facts for the build that are given:
- targeted speed: 6-7km/h
- targeted manageable slope: 12% / 7°
- end wheight: 800kg (based on my calculation that makes 1200Nm necessary for driving uphill)
- one separate motors for each wheel
From my calculations i think i require two motors with at least 4, better 5 Nm of torque.
An additional problem is the targeted speed. I can only fit a sproket with around 50 theet on the axle because of the limited space. To get to my desired speed with the current wheelsize the motor shouldn't have more than 500-600rpm, so i'm somewhat limited to motors with a build in gearing.
Now to the parts i thought about using:
Battery:
Aliexpress
Motor:
Aliexpress
I would use the 48v version. Also this motor has the advantage of a build in gearing which together with the sprocket i think i can get to a gearing of 1:30. Although the seller suggests a possible load of 1000kg for a single motor, i'm not sure if that's realistic based on my calculations above.
I'm happy to hear about alternatives and am grateful for any feedback i can get on my plans and will update on the build making progress.
Battery:
Aliexpress
Motor:
Aliexpress
