bombadero
- Joined
- Jun 19, 2019
- Messages
- 32
Hello, I had an arc fault a few months ago that has taken a while to repair. I've recently replaced the torque sensor, an ERider T9N, and while my bike is mostly restored now, the regen, human watts and other metrics are diplaying outlandish numbers and I have to set the starting watts of my PAS to -30 HW in the CA3 PAS screen to get it to work at all. That's the TL;DR. More on the arc fault, which is now fully repaired, can be found on this separate thread.
If you've read this far, here's a bulleted summary in between the TL;DR and reading that other thread in full:
0. I have a dual-motor, dual-battery, 52V e-bike wired in parallel. His name is Bruce the Moose. He is a bike tractor.
1. I had an accident that tacoed my rear wheel; I did not realize at the time, but it also mechanically damaged an XT-90 connector coming out of the rear controller.
2. The negative wire on the XT-90 came loose from the solder cup during a ride, causing an arc fault that fried my CA3, wire harness and torque sensor.
3. I soldered a new, custom wire harness with XT-90 and XT-90S connectors that is shorter and better protected by the frame, and repalced my CA3. So far, was so good.
4. I replaced my T9N sensor with a new unit from Grin, but had weird issues with it. It would only provide assistance if the bike was pedaled in reverse. There are some additional details to this I can provide here or you can read about them towards the end of the other thread.
5. I replaced the T9N again with a sensor from Aliexpress, and the bike now works but I have these weird outputs and have to set the start threshhold to -30 HW to gain any assistance, and even at that level I have to pedal pretty hard to get assistance.
I should also mention the assistance is a little inconsistent. Every once in a while it cuts out altogether at speed (but well below top speed). In these cases, If I hit the throttle, it becomes available again after I release the throttle. At other times, it will kick in with very light pedaling, which one would expect with a negative 30 threshhold, but when starting from zero I almost always have to use the throttle no matter how hard I pedal to start.
I have ordered yet another sensor from Grin that I haven't picked up yet. One thing still to try is to install that sensor and compare to the other two. Summary of the sensors/history for clarity:
0. Original sensor. Burnt out in arc fault.
1. 1st replacement (Grin). Damaged, provided no assistance (magnet spindle somehow bent).
2. Hybrid sensor (new Grin sensor + old sensor's un-bent magnet spindle). Only provided asistance in reverse. When setting 5V gain to reverse (which is the opposite of what this sensor requires), rather than flipping the behavior as expected, this hybird sensor instead provides no assistance.
3. 2nd replacement (Aliexpress). Currently installed, working with described wonky behavior.
4. 3rd replacement (Grin). Not yet picked up or installed for comparison. TBD.
Photos of the strange outputs from the CA3:
I used -47 Ah on my 14 mile ride!!!
My bike is a power generator apparently!!!
