AussieJester
1 TW
mwkeefer have you tried any of the sp320 meanwels yet? I haven't moddded mine at all and it happily charges my pack
without even getting slightly warm.
KiM
KiM
Hyena, thanks for your reply. I have a kill-a-watt. So I thought I would hook up the PSUs without any mods and see how much power they would draw. When I was hooking up the Negative lead to the pack there was a loud pop and spark. I took the lead away because I thought there may be a problem. I checked the PSUs and they still seemed fine, but I would like more advise before hooking up again.Hyena said:baerfoot read back through the thread (last 10 pages atleast) - you'll need to limit the current or they'll likely quickly blow up - especially running for hours with a 72v100ah pack!
I find that if I plug my power supply into the wall first it won't arc but I unplug it from the wall before un hooking it from the batteries! The last time I used mine I uhnhooked it from the batties in the middle of charging and fried 2 fets! It's all a matter of having the voltages as close as possible before conecting wires. I also. Use the power supply to charge up the controler before hooking up the batteries and it prevents arcing!baerfoot said:Hyena, thanks for your reply. I have a kill-a-watt. So I thought I would hook up the PSUs without any mods and see how much power they would draw. When I was hooking up the Negative lead to the pack there was a loud pop and spark. I took the lead away because I thought there may be a problem. I checked the PSUs and they still seemed fine, but I would like more advise before hooking up again.Hyena said:baerfoot read back through the thread (last 10 pages atleast) - you'll need to limit the current or they'll likely quickly blow up - especially running for hours with a 72v100ah pack!
Is it normal to have that type of arcing when hooking up the leads? Is there a way to prevent it?
GGoodrum said:I have the same S-350-24 supplies and it took me all of ten minutes to open up one unit and tack on the extra resistor required to lower the current.
-- Gary
Let me know how I can help, although I don't have much experience. For instance I would not be sure how to reassemble the heat sinks correctlyif I removed the PCB.mwkeefer said:If we can isolate that your PCB is identical to most of ours the defacto std design - ours have locations for SVR2 but it's not populated... if we can lift the components used in yours and the surrounding circuit we can adapt it to a module - easier to construct and would allow dial in of the current on these models as designed (well in yours atleast)...
This is actually how Fecther figured out the mods in the first place we posted pics of the PCB around the TL494CN chip and then I scanned some and finally I sent him a unit for testing and modification...
Now I don't know - 22 pages later, well...
I should give credit to Tiberius and Jermey Harris too... they did start this whole bit off in another similar thread.
-Mike
Hey man thanks but what I was trying to say is my last S-350-48 does not have a 110/220 switch where it should be! its missing! I do have a S-350-48 that I blew up real good so I will look at pulling the switch out of it.mwkeefer said:Arlo,
The switch needs to be set for your AC mains voltage - 110 in the states (unless 3 prong 220) and 220 abroad... if it was set to 220 and you used it on 110 it will produce about 1/2 the output power and high end voltage range - also if you hook to 220 with 110 set you will blow the unit out without a doubt.
Now 2 x S-350-48 tuned to a no load (CC/CV crossover point) voltage of 104 and an assumed even split of 52v each supply...
700 / 104 = 6.73 A - this is the rate you should see the charger running at without any further mods (assuming they sustain).
If one of the units was set for 220 it would produce 1/2 (roughly) it's potential or 175w so... 525w / 104v = 5.048 A
If both units were configured for 220 it would be 350w total and at 104v that is = to 3.365 A - sounds like what your seeing though it could be damage to the flyback diode...
Check that both units are set for your AC current.
One further thing - what are you charging with these? Chemistry I mean... LiFePo4 would have higher Internal Resistance and thus may draw less power... have you done some current limiting and have you modded the units to replace the thermistor with a resistor so the fan stays on?
-Mike
