t_tberg
I just bought a 20W led headlight that I've connected to the pack voltage via the CA's 5.5x2.1mm power plug. The light works fine, however, whenever the light is plugged in the throttle does't work properly; depressing the throttle completely only results in pluses of power. The problem goes away if the light is unplugged. I'm not sure if this is related but the CA tends to change to the next menu screen on its own sometimes. Has anyone had any problems like this while using the CA's power plug? I'm using the CA V2.3.
