*bought them from elitepowersolutions.com
*you buy the batteries up front...then she sends you another bill in your e-mail for the shipping cost...shipping wasn't too bad..only about $20
*paid about $380 for them but they are on sale now for $104 per pack I think
This is my 2nd e-bike. My 1st one still runs, though. I bought the bike used.
* I have a 5303 hub motor with a 36v - 72v 35amp controller.
* I now have 48v on the bike. Was using 36v20AH thundersky for 3 months and then decided to buy another thundersky 12v pack to make it 48v.
* I weigh about 267 lbs.
* I've had the Thundersky's since january of 2010
* most AH that I've used is around 10 (50 % of the pack)
So far so good. I pull about 2C out of these batteries.
EDIT:
GET A BMS FOR THESE CELLS. IF THEY DROP BELOW 2.5V EVEN ON VOLTAGE SAG. YOU CAN DAMAGE THEM.
I'm happy with them. I've charged them about 5 or 6 times now without balancing (topping them off) and they are still pretty well balanced. I was balancing them about every time. I've heard that the 36v 6amp charger that comes with them from elitepowersolutions.com is not very good, though. The people that are having trouble balancing your batteries; I don't really understand how it is that your batteries get so out of wack. Maybe mine are all from the same batch or something. I recommend using a 12v black and decker charger with a 2/6/10 amp setting on these because it tapers the current as the battery gets full and does not damage the batteries.
EDIT:
In the beginning, they did get a bit out of wack at first but I think once you cycle them they seem to all behave the same way and nearly same voltage. I charged them at first and one was about .1v or .15v off but that doesn't even happen anymore now that I have about 25 cycles on them.
EDIT:
EDIT:
