jamiejackherer
1 W
- Joined
- Jun 11, 2019
- Messages
- 59
jamiejackherer said:What a stupid question.. clearly I don't own a CNC machine fella.. but just because you do it doesn't mean everything you say is true.. my pal works at a mutli-million pound company.. I really don't understand why people in this forum are so negative and oppressive tbh. If I can get it done cheap, isn't that a good thing?larsb said:I know that can be done but if you've ever paid for the energy and work you consume you wouldn't say that it's a good idea.
A huge waste to melt metal, shape a block, cut it into a smaller block, cut that block into small fins with the majority of the material going to waste as well as the power to the machine and cutting fluids, collect the millings, spend a gigamillion Wh to melt aluminium again, chemicals to clean it from the slur etc.
I own a CNC machine by the way, do you?
Seems everyone in this post wants to tell me I can't do something. I won't be able to. Or it's been done already so I should spend all my hard earned cash on their overpriced product. [emoji1787][emoji1787]
If HubSinks are $79 and they run the business to make profits then they will be putting at least a 75% profit margin on the product (standard business practice) which means it costs $20 to produce. If they can do it for $20 then so can I![emoji23]
Sent from my SM-G970F using Tapatalk
jamiejackherer said:[emoji1787][emoji1787]Ianhill said:jamiejackherer said:What a stupid question.. clearly I don't own a CNC machine fella.. but just because you do it doesn't mean everything you say is true.. my pal works at a mutli-million pound company.. I really don't understand why people in this forum are so negative and oppressive tbh. If I can get it done cheap, isn't that a good thing?larsb said:I know that can be done but if you've ever paid for the energy and work you consume you wouldn't say that it's a good idea.
I was far from negative and oppressive so before you use long words like that best you have a good understanding of them, i offered you a solution ans spent time telling you but as pig headed as you are lesson will have to be learnt yourself.
By the way any multi million pound company worth its salt will only let your silly games get in the way of mill time when the machines are down and theres also a que seems you want it all and have an attitude about it ive helped all i can best of luck with your thick arse heatsinks thank you for offending when i offered a solution.
Sure, but once you have that thermal bridge, there's dramatically less need for additional surface area -- you'd have to be into magnetic saturation.spinningmagnets said:However, if you add 10ml of ferrofluid, there is a huge benefit to heat-shedding, and once FF is added, hubsinks boost that effect significantly.
