kZs0lt
I have a 12 FET Infineon controller from ecrazyman, this is probably the soft start version. And an ecrazyman hall effect thumb throttle.
The throttle response is sometimes like intermittent. The throttle response is not linear, at the end the current rise is steeper. But the problem is, it seems like I don't get the same power at the same throttle position. Worst is when I am ascending a like 8-10% slope(BMC motor), I can't stay smoothly at 15km/h for example, as when turning throttle, at a point I get a burst, of around full throttle(have no ampmeter), till get to like 18km/h, then it backs off power and I slow down to like 12km/h and it kicks in again, there is not a slow ramp. It's like not having anything above mid current, but only full. I am using 66v, but it's the same on lower voltages too. I am also using a 4 step switch programmed to 30%, 50%, 70%, 100%, But I get the same effect on every setting, it seems like it is not connected to a certain speed or voltage, but more like to load. If I want to accelerate very slowly on flat, I can get to full speed smoothly, but once I want to do it a little quicker, somewhere it would kick into full current the throttle being only about 70% WOT.
I'm not sure what the throttle is supposed to alter current, voltage or duty cycle, but this is very annoying, with kick-ins all the time while I keep trying to ride with smooth handling on throttle.
Is this unusual, or others have encountered the same? What could be the cause, or how could this be remedied?
Could this be caused by the resistor that I have put in series with the throttle signal earlier(see here). I'm not sure, but I think it acted the same before that. Could it be caused by thin and long wires to throttle?
What tests should I perform, to investigate further the problem. Should I try with a resistor pot instead of the hall sensor?
