Dui ni shuo de dui
Hello everyone,
I've seached a little bit on this forum and did not managed to find any interesting information regarding ultracapacitors yet, so I've decided to create this topic, which hopefully will help me among with other interested people to gather as many information as possible on this technology.
I currently own an electric "big scooter", with 72V 50Ah lithium battery, 2000W QS motor and 72V 150A Sabvoton controller, and, while this setup is quite nice already, I would like to improve it a little bit, maybe by adding some ultracaps.
The idea is the following:
Currently, under big load like a full throttle acceleration, I can see the voltage going down from approximately 78 V to 70-71V. I assume that this is due to the internal resistance of the battery cells themselves that may not be able to provide sufficient current, probably because of a low C rating. The voltage goes up and remains stable while the scooter is speeding up.
I assume that, if I can find a way to buffer some electric power in between the controller and the battery, It should prevent this voltage drop, thus increasing performance and battery reliability.
The idea I have in mind is to use High charge/discharge rate components, and the ultracaps seems very appropriate to do this. Basically, I suppose I should place some ultracapacitors somewhere in between the battery and the controller, but I feel like it should not be just that simple.
For instance, after the ultracaps are being discharged, they may try to draw current from where it's available, ie: the battery. Since their charge rate is very high, they will ask the battery for too much current so I guess that there should be something for limiting this supply.
Anyway, I do not have any clear idea on how these things should be properly integrated. Would someone in this forum be kind enough to explain it to me? Any documentation, schema, picture, tutorial or whatever would be very much appreciated
