teslanv
Subscribed.
GiantEV said:Routybouty said:maxRpm said:I am curious to know what kinda of battery setup is everybody going with. I had planed on using multistar 6s 16000 battery's but seem like there on back order and will be for a while.
Routybouty, I'd like to see pictures of how you fit your batteries in your Vector frame.
moonshine said:Anyone else have suggestions for slackening head tube angle?
For the crank alignment I'm gonna switch the front chain ring to the inside, press the cranks in more, and get a 3 speed cassette to push out the rest further.
The max voltage you should go is 22s.maxRpm said:That's awesome, I notice that these battery on HK are going for good price but is it possible to fit a 24s arrangement in there?
Why?striker54 said:The max voltage you should go is 22s.maxRpm said:That's awesome, I notice that these battery on HK are going for good price but is it possible to fit a 24s arrangement in there?
maxRpm said:Why?striker54 said:The max voltage you should go is 22s.maxRpm said:That's awesome, I notice that these battery on HK are going for good price but is it possible to fit a 24s arrangement in there?
What would be a good BMS for these batterys that has high discharge 60+ ampsGiantEV said:Looking good.... that's a lot of lipo!
In this picture from the Vector thread the batteries are stacked upright, but there's a lot of wasted space at the top. Figuring out the best way to stack and secure the batteries is all part of the fun of building an ebike I guess.
maxRpm said:Wish I saw this before I order my lipos from hobby king http://www.alibaba.com/product-detail/The-highest-discharge-rate-and-capacity_60062078132.html
More interested in the controller cover when will it be up for sale?Artur said:you always can use set of spacers if you need a bit more space
maxRpm said:More interested in the controller cover when will it be up for sale?Artur said:you always can use set of spacers if you need a bit more space
