ian.irmischer
- Joined
- Sep 29, 2013
- Messages
- 11
dogman said:10 ah will be big enough. Wattage ratings of kits is so full of bull, but 12 amps controller is small, so 10 ah is ok.
Hopefully the bottle battery comes with some kind of plug and wire to connect to the bottle. The other end, you put a connector onto that that matches the plug on your controller.
Those bottle batteries bolt to the bike using the same bolt holes in the frame you would use to put a bottle cage on a bike.
Dogman, Have you seen the KEYDE batteries at all? I have heard good things about the BMS batteries but the KEYDE batteries seem much smaller and it doesn't look like they come with mounting hardware. It seems like they just want you to throw the battery in a water bottle cage.
Any ideas?
