kmxtornado said:
I too was thinking I could use the same connectors but different colors.
Except for gray and black which are keyed the same, all the other SB-series shell colors are keyed differently so they can't be plugged into each other. So as long as you use colors that are not keyed the same, then you can't cross connect even in the dark.
(that is a problem that has destroyed things for a number of ES members over the years...they didn't think they'd ever need to worry about it, then one day (or night) they decide to connect something with insufficient lighting, and....
I liked that idea but I noticed the wires on my battery for charge and discharge are vastly different and figured it may be weird to put a giant SB50 one on a small 14 gauge wire.
They make different contacts for various gauges of wire:
https://www.andersonpower.com/content/dam/app/ecommerce/product-pdfs/SB50/ds-sb50.pdf
View attachment ds-sb50[1].pdf
So the setup I'm thinking is APP45 for charging on what I believe is a 14AWG wire and then the grey SB50 for discharging on what looks like a 12AWG wire (or possibly 10AWG). I'm not really sure how to tell.
If you have the option to get the non-black/non-grey color housings, I'd recommend that, because they can't be connected to other colors--no accidents as long as you never use the same color on a different voltage or other purpose than what you use it for here.
Can you tell me what range of gauge of wire is needed for APP45 vs SB50?
The PDF above has all the data for the SB50 series contacts vs wire gauges, so you can choose the right contact for your wires. The wires themselves you should choose based on the current flow required in that part of the system.
This one has the PP45 data:
https://www.andersonpower.com/content/dam/app/ecommerce/product-pdfs/DS-PP1545.pdf
View attachment DS-PP1545[1].pdf
I recommend using the highest retention-force contacts in whichever size you end up with, so they can't accidentally become unplugged, unless you have a specific reason to make them easier to disconnect.
What do you mean by "floating" in the shell?
Most connectors are designed so that the contacts must be installed correctly and well-aligned already, or they don't mate correctly..They're usually held reasonably tightly in the shell so they can't move around, so they can't really self-align.
Some connectors are made with various self-aligning features, but to work these require that the wire or it's insulation not be too thick and fill the back of the shell, and that they not be bound prior to entering the shell in a way that prevents them from moving with the contact, or else the contact can't move around (float) inside the shell during mating and self-align.
SB and PP connectors are designed with a flat mating surface and a spring under them in the shell, so that they can be misaligned to some degree when connecting them, and they'll still self-align and correctly mate.
If the wire or it's insulation is so thick that it touches the shell, it may prevent the self-align process. If it's actually forced against the shell, or tied down such that the contact can't move, or is actively twisted relative to the shell, it can prevent the self-align process from working at all, and only the edge of the contacts will mate, making a relatively high resistance connection. This is what causes many of the anderson failures you see where the shell has melted or deformed--the deformation itself causes further misalignment increasing the resistance and can even lead to a fire for really high current connections.
The PP connectors are more vulnerable to heating deformation from this because they use a softer plastic in a thinner shell than the SB series. But all of these connectors are vulnerable to these problems, so if you need to secure the wires leading to them that should be done so that there is enough loose wire into the back that they can still perform self-alignment correctly. Anderson has hardware made to help with this for various applications.
If you have any of the PP45 connectors you can play with them and force the wire around in the back of the shell and watch the contact move, if the wire is thick and/or stiff enough.
Absorbing the spark from initial connection would be great. That always kinda scares me.
The spark is sitll there. It doesn't absorb the spark itself, just the damage the spark causes, since the wedge-shaped tip is there to be eaten away each time it happens without damaging the actual mating surfaces.
To prevent the spark you'd usually need to use one of the many precharge setups discussed around here the years.
