mr.pibb
1 W
- Joined
- Sep 15, 2012
- Messages
- 58
OK I am brand new to the forum. I just really started looking into electric bikes only within the last week.
I love what some of you guys have come up with and I had to join the forums.
I have owned a curry trailz for about 2 years and love it.
Before recently watching youtube videos inspiring me to join and build a new bike, I started small with some ideas of my own on the trailz.
1. I added a HUGE honda goldwing trunk to the back for storage. As a bonus I got intergrated taillights in the trunk with a built-in back rest as well.
2. I have ugraded the batteries (twice now) to larger sealed lead acid mounted on the sides where the old battery went.
Currently I am running 24v with a capacity of 35 ah. This give me an insane range of 50 miles, but realitively slow 17 mph compared to other bikes.
3. I am adding a 40 watt solar panel above the trunk sort of like a spoiler if you will. (ordering now)
I will post pics soon.
The bike is fun and perfect for a beach cruiser. I can put towels in the trunk and whatever else I need and have a fun day.
However now I am onto a new project. I want to make a "commuter" bike capable of near 50+ mph!!
I have a donor bike that is a a2b ultra motor velociti 26.
Nice bike but no battery so I want to do a complete overhaul.
Here are my plans:
crystalyte hs-3548 rear hub motor
crystalyte controller
crystalyte apm led readout
96v total SLA batteries (8)*12ah
Heres where my issues come into play. I originally was just going to upgrade to the hs3540 and be done. But I was thinking:
I could put the stock a2b 500 watt rear motor to the front of the bicycle and instead get a hs3548 for the rear. I would be losing the off the start torque with the 3548 motor vs the 3540. However with the "boost" of 500 watts from the front motor I would estimate the take off to be about equal to the 3540. And I would get a higher top speed with the 3548 motor!
(I would only really use the front motor for torque boost for off the line starts. I image at speeds higher than 20 mph it would not help any because thats the top rpm of the motor)
Do you think my "idea" sounds about right?
Now the issue is the rear hub doesnt fit in the front forks.(thanks murphy! :| ) I would have to get wider forks. Standard width is 100mm.
I have found I can get 135mm wide forks realitively easy. I am not sure if that is even big enough. I need to get the free wheel off first to measure it, but it looks really close. Has anyone done anything similar? I found this fork on ebay: http://www.ebay.com/itm/SURLY-PUGSLEY-907-FATBIKE-OFFSET-135-MM-FORK-LARGE-MARGE-SNOW-BIKE-/251151310124?pt=LH_DefaultDomain_0&hash=item3a79c8dd2c Do you think it would work?
Do you think it would be worth it to use the old 500 watt hub motor or to ditch it all-together? I really dont have another use for it so I figured it would be worth reusing?
Thank you for taking the time to ready my long post. Just had a lot to say right off the bat. Thank you also in advance for any help or advise !!!
PS: I know SLA is not the way to go but I dont have the funds for lithium and I understand that lithium is better. I will try to upgrade that later in the future.
Here are my plans:
