chas58 said:Battery question:
In the interest of light weight, I would like a 36v8Ah battery for short trips (wt: 2kg), and to use a second 36v8Ah for longer trips (i.e. use the second battery for the second half of the trip).
http://www.bmsbattery.com/36v/514-36v-10ah-lithium-ion-electric-bicycle-battery-pack.html
That would allow me to be light and quick for shorter trips (80% of the time), and have the option of going longer on those days when I needed that.
Or is there a power disadvantage with using a 36V 8Ah 15amp battery vis a 36v 12Ah 15amp battery?
(I am avoiding the bottle batteries there, as they look to be only 10amp sustained).
You can't use these batteries with any motor more than 250w. They can't give enough current. The lightest weight options are the 15aH shrink sleeve battery for 350w kit and 20aH version for 500w.
http://www.bmsbattery.com/36v/445-36v-15ah-lithium-ion-electric-bicycle-battery-pack.html
http://www.bmsbattery.com/36v/165-36v-15ah-lithium-ion-electric-bicycle-battery-pack.html
The 350w CST motor gives much less torque than the 500w one - even if you run it at the same current. The size and weight are the same as the 500w one, so no real advantage. The torque difference is less noticeable with the BPMs. The main difference with the kits is the 22amp controller with the 350w kit and 30 amp one with the 500w kit. The 350w motor is strong enough if you don't weigh too much, or if you don't have extremely steep hills. If you weigh 100kg, 500w is more comfortable.
