Punx0r said:I'm sure when the hydro dams were proposed there were critics who said it wouldn't work/would be too expensive/too intermittent/that we'd never run out of coal.
sendler2112 said:Hydro power rocks! It must be developed where ever it is even marginally feasible and any ecological or social issues opposed to it's build out must be secondary. To demolish any existing and well producing still viable hydro projects is a big step in the wrong direction.
Chalo said:I don't believe I'm alone in thinking we'd be better off with another Yosemite than with another dam.
As always, people will trade off economic necessity with preservation. We are getting better at that.sendler2112 said:Hydro power rocks! It must be developed where ever it is even marginally feasible and any ecological or social issues opposed to it's build out must be secondary. To demolish any existing and well producing still viable hydro projects is a big step in the wrong direction.
What do you suggest can be done ?Punx0r said:The area of the outback is more than an order of magnitude larger than the area of PV required to power the entire planet. With vast areas full of almost nothing except intense sunlight, I'm sure something can be done.
Hillhater said:What do you suggest can be done ?
Hillhater said:For those with a fobia about carbon, New technology Nuclear/Fusion is likely the most realistic bet currently.
Punx0r said:Hillhater said:What do you suggest can be done ?
Until a practical, reliable, economically viable, system of storing (and tranferring) huge amounts of power , ..is available, Solar or Wind are not a practical solution without equivalent back up from Thermal generation.
Well, you could power a minimal night time load with fossil and cover the extra daytime usage with solar. If you must store solar energy then molten salt is probably the cheapest (right now) for large scale. But no, 100% thermal back up of solar & wind is not required, that was addressed earlier in this thread.
Only reason we have freak warm days like Penrith city record, is due to the fact they have created a record amount of new concrete housing and roads since last few summers.Punx0r said:See, this is the problem again, you don't believe carbon dioxide is causing climate change so you don't see a problem with coal, let alone grasp the urgency of the problem. Emission need cutting greatly and quickly, cost almost shouldn't be an issue. That's a strawman argument: you know as well as I do that fusion is always 50 years away and next gen nuclear (the inherently safe, non-proliferating, waste-free one) 10-20 years away, so your argument is actually: let's do nothing and just keep burning coal "in the meantime" (meaning: for the foreseeable future).
Hillhater said:I just came across this site for the Australian King Island RE Project.
It has a really nice "real time" graphic interface to show what is happening..
http://www.kingislandrenewableenergy.com.au
Maybe you can explain to those who have tried, S Australia, Germany, Spain , etc....exactly how to make that work without 100% thermal back up....because they still need it.Punx0r said:Well, you could power a minimal night time load with fossil and cover the extra daytime usage with solar. If you must store solar energy then molten salt is probably the cheapest (right now) for large scale. But no, 100% thermal back up of solar & wind is not required, that was addressed earlier in this thread...
Thats satellite temperature readings for a large area, I am talking about all the jumping up and down that was in the local media the other week because hit high 40s for like 30minutes in the afternoon. Looking at temps for the local city after so much new building and chopping of trees is going to make that localized spot get more warm.jonescg said:TheBeastie said:Only reason we have freak warm days like Penrith city record, is due to the fact they have created a record amount of new concrete housing and roads since last few summers.
frock me, Penrith must be a big suburb - clearly takes up half the continent...
You are correct that the local environment (and measurment equipment) has changed significantly,...but,..TheBeastie said:Only reason we have freak warm days like Penrith city record, is due to the fact they have created a record amount of new concrete housing and roads since last few summers.
Ahh .. Good to see you are beginning to understand some of the issues.!Punx0r said:Let me try and keep track of the claims made just today
* The increase in heatwaves is the result of concrete paving and structures, not GW (or just in Penrith, Aus?)
* Modern heatwaves are not a cause for concern as it was once even hotter somewhere nearby ~100 years ago (oh, and there's a conspiracy/cover-up)
* Any RE always requires 100% thermal backup (or just solar or wind?)
* Replacing trees with concrete or desert increase GW as the albedo is lower for trees
* PV plants are always (or nearly always) sited by clearing forest (or is it now just where forest could/should be?)
* Thermal storage doesn't work in winter in the Australian interior (because the sun doesn't shine?!).....
(Even that was incorrect)Meteorology (BoM) revealed that Penrith had beaten Sydney’s previous record of 47 degrees, which was recorded in Richmond on February 11, 2017, at 3.25pm yesterday.
However, the BoM later revised their statement, saying 47.8 degrees had been recorded in Richmond in 1939.
Yep. It's denier 101.Punx0r said:This reads like AGW denialist rhetoric 101 and I have a strong suspicion that this isn't a technical discussion at all. It's just an opportunity to attack anything seen as green. Never mind that RE could also improve energy security and reduce global conflict.
If you hit the "History" tab ..and then "page back" ??... I get a drop down menu to detail the installations.sendler2112 said:Hillhater said:I just came across this site for the Australian King Island RE Project.
Very interesting. Too bad the web site is so weak in documenting the installations that are there. They have chosen a very small proportion of solar PV. Must be stormy there? Nice job in reducing their diesel consumption by 45% last year. I wonder how much more oil is consumed for heat in the winter there and on TAS.
Hillhater said:If you hit the "History" tab ..and then "page back" ??... I get a drop down menu to detail the installations.
Summary..
6.0 MW of Diesel generation
2.45 MW of Wind
100 kW of Solar (with another 377kW of private distributed installations)
And a Redox battery (currently out of service)
Approx 2+ MW max demand.
Hillhater said:Ahh .. Good to see you are beginning to understand some of the issues.!
(And i guess repeating it may help you remember ?)
Hillhater said:[The Australian BOM (Bureau Of Metrology) has been discretited several times recently for failing to represent the facts accurately, ( conveniently resulting in current temperatures appearing to be higher than previously recorded ?)
They have ommited extreme leow temp readings from some stations, revised (upwards) other recent minimum temperature readings, and as this last episode , deleted from their official records historical high temperature readings !...amoungst many other "errors" .
Fraud ?.. I think the words i used were "sloppy" , "discretited", and "failing to represent fact accurately" ..Punx0r said:Hillhater said:[The Australian BOM (Bureau Of Metrology) has been discretited several times recently for failing to represent the facts accurately, ( conveniently resulting in current temperatures appearing to be higher than previously recorded ?)
Are you really so credulous?
Anyone who has ever conducted any kind of technical or scientific measurements or statistical analysis (or process control) will understand immediately that these kind of claims of "fraud" (which have seemingly been levelled at nearly every meteorological or climate science organisation) are ridiculous.
Hillhater said:But you seem to agree that most similar organisations have the same sloppy approach to their role ?
Hillhater said:They record single momentary peak temperature readings from electronic thermometers as accurate data, with no attempt at averaging over a valid time period, or compensation for "noise" and log it as a permanent record.
They also change those data points at will with no archive of the original data...not exactly scientific !
