Thanks AW. I finally found it under 'my account'. It's called following. I don't remember following anybody, but who knows...I *think* the NF shows only posts from people on your watch list (or friends or whatever its' callled in XF), so if tha'ts the only person there, they may be th eonly one on your list.
Was the latest activity option causing problems? I sort of like that one, since it showed all activity on the forum chronologically, so if there were 3 or 4 responses to a thread, you could see them all there, with the first couple sentences of the responses. The current options only provide the latest post on a particular thread, but not all of the activity since you were online last (it also helps to see the duplicate posts, etc., since you can see the first sentence).Updated the navigation to return 'what's new' and 'mark forums read' functionality. New (unread) is now = 'what's new'.
As you notice, we removed the left hand menu in the navigation options because it's redundant and confusing now. We have a new problem in that these displays are now 'too wide' as a result.
I have a counter-adjustment in mind that should come in a few weeks.
What does "all activity" show, everything? I use "watched" more than anything so would not like to see it replaced with something that includes other threads.No, not causing problems, but the menu is quite busy already.
I think it would be reasonable to remove 'watched' and add 'all activity' in it's place, because all threads you reply to are 'watched' already; which makes the feature redundant for anyone other than thread stalkers.
What does the crowd think?
I would replace the first "new" with "all activity", because they most closely match the same function, of all the things that could be replaced, and "new (unread)" appears to be a more useful version of "new" if both can't be there.I think it would be reasonable to remove 'watched' and add 'all activity' in it's place, because all threads you reply to are 'watched' already; which makes the feature redundant for anyone other than thread stalkers.
FWIW, the ACP says there are 65,997 members (on the List All Users page) in 3300 pages of 20 users each. This list appears to include all banned members and spammers as well as inactive memberships (deactivated or never activated by the user).Member counts are still incorrect, ~55,000 shown, ~83,000 is actual.
I'm for "new"; it seems most useful since it's not filtered/narrowed, while "new, unread" applies a specific filter (based on user login; odd that the system is tracking and storing each action a user takes, but I guess that big data). The ability to mark something read or unread, beside opening a thread or logging out, only appears at the subforum menu level. At that level, the user can mark the entire subforum as "read", but there's no ability to mark it as unread (or mark any thread or forum as "read" or "unread").'I would replace the first "new" with "all activity", because they most closely match the same function, of all the things that could be replaced, and "new (unread)" appears to be a more useful version of "new" if both can't be there.
EDIT2: I noticed something else, and not sure what it does. On the results screen, after clicking the "new (unread)" option, a button appear that says "Show only Unread" which is odd, since I thought that is what the option results would be. Clicking the button changes to results, and in my case increased the number of (unread) posts. What does that button do, and is there a way to move the button to the "new" results screen, thereby allowing one to see all new posts, and then filter for unread??
I would like to see a "in memory" section somewhere too. We have lost a few who deserve a memorial. farfal, etc.You can tell there's tweaking going on. Something is there one minute, gone the next, then comes back.
Anyway, is there a wish list or suggestion thread for the XenForo implementation?
The members page needs help to make it usable, and there may be some quick/easy fixes to help with navigation. Find a Member search is pretty much broken. Navigating to find someone in the middle of the alphabet takes some doing, even with editing the url page number with guesstimates. Adding an alphabet navigation option as a quick fix would help until the search works.
A couple of things that aren't really suggestions, but maybe food for thought. It really depends on the the kind of culture or community feel you want ES to have, I guess. Part of that is the look and feel, and part is the content:
I have some other thoughts around creating a real Home page. "Home" is redundant on the navigation bar, since it's the same as "Forums". Maybe a What's New page too.
- I see that some forums have added a subforum for new member intros. Voluntary, but it's one place where new members can add a little intro post and others can go see who's joined lately. That might go in the Biker Bar, or incorporated in the members page.
- Another subforum that I've seen has been something like "In memory of". ES has been around a long time. I belong to some other forums with a long history, and the subforum is a nice place to recognize the contributions of members who, in this case, have ridden off into the sunset.
well the smiling poo emoji is more positive than a frowning poo...While I would like to see the ability to give negative feedback, when I asked about that previously, I was advised that only positive feedback would be allowed, for reasons I'm sure make sense.
