safe
1 GW
- Joined
- Dec 22, 2006
- Messages
- 5,681
LiFePO4 verses NiMh
Let's look into some of the issues associated with NiMh verses LiFePO4.
Gravimetric Energy Density:
NiMh : 60-120
LiFePO4 : 90-120
(about the same)
Load Current:
NiMh : 5C (peak) : continous is more like 3C : best 0.5C
LiFePO4 : 30C (peak) : continous is more like 15C : best 10C
(big advantage for LiFePO4)
Well you can see the chart...
One big issue is charging. Correct me if I'm wrong, but LiFePO4 exibits the same behavior that NiMh does when charged in that if it's in series it takes only one bad cell to trick the charger into believing that the charging is complete. In the worst case scenario you can get all kinds of weird cell reversal going on and it means that you need to do something like:
1. Use a Battery Management System even though you really are not likely to break the batteries, but if you don't and you have a fixed pack design then you can lose capacity if you don't charge balance.
2. Do something like I'm doing where you never solder your pack together and periodically disassemble your pack (in my case spring loaded cells) and inspect each cell individually to do a sort of crude balancing every once and a while.
As far as price, my numbers point to LiFePO4 costing twice as much to buy, but then when it comes to cycle life that equalizes and you arrive at about the same price.
What's the long term life span of LiFePO4 not counting the cycles?
How long could a LiFePO4 pack live if you DIDN'T ride very much?
NiMh : 60-120
LiFePO4 : 90-120
(about the same)
