tmxl69 said:
Ok so NIMH isn't the best choice for building a 36V pack but at $100 out the door for 30 D cells wouldn't this be a better option then using three 10a SLA batteries?
That would depend on *which* D cells and which SLA. There are some great SLA out there and some really crappy ones, and the same goes for NiMH, with double on the crappy.
With the NiMH, the catch is that many (probably most) of teh cells out there regardless of physical size are relatively high internal resistance, so when you draw ebike-level currents out of them, then:
A) they get hot faster, with a lot of voltage sag, which both prevent getting good performance from them
and
B) they don't give you nearly the rated capacity, so a 10Ah cell might only give you half that, or some other significantly-less-than-rated amount (because the rating is at a much lower current draw, like maybe 1/10 capacity (C), or less).
If they're really cheaply priced D cells, it's a fair bet that they're in that class, and not going to give you what you expect. Use them in a flashlight or something, which is probably what they made them for, and they'll likely work great. Maybe even in cheap power tools, though not as well or for as long.
I can't remember for sure the name of the brand of cells in the packs I have from Deardancer and Ianmcnally, but I think it is Sanforce, and another good one is Saft (not sure if you'll find the Saft for sale anywhere, though). Those cells are good, and perform well at high C-rates. Anything else I couldn't vouch for.
Some SLA are great, too, like the ones made for powerchairs and the like (as opposed to the typical UPS SLA). As Ypedal says, they can often put out huge currents for a very short time, like during motor startup, which NiMH D cells sure won't do in my experience. 17Ah and 20Ah SLA I had on CrazyBike2 were able to supply 130A+ long enough to taco my chainrings, rip apart the chain, destroy the rear rim and bend the rear axle as it pulled it out of the dropouts before the controller exploded, when I had a derailment of the chain on a powerchair motor drivetrain experiment. :lol: The Nimh D cells would likely have been unable to even bend the chainring; the F cells might've managed that but little else.
