valerun
Hi All -
The same thread on DIYelectriccar.com got ~200,000 views and ~1,300 replies to date so I figured I would start a similar one here to make sure as many people as possible know about this product.
Over the last couple of years, my team has developed a 12kW / 70A charger design that exceeds all known chargers available on the market today (that you can put into a vehicle, anyway) - both in power and features. We just hated to pay $4000 to be able to charge our conversions in less than 5 hours...
An incomplete run-down of the capabilities:
* 12kW rated power - tested to 15kW continuous with liquid cooling
* 100 - 260VAC, up to 400VDC input
* up to 350VDC battery voltage (up to 425V with very minor modifications)
* fully PF corrected option available
* 144x144 color screen for controls & readout
* Fully digital control by built-in Arduino system
* All battery types supported with micro-processor controlled charging regimes
* Integration features - BMS cut-off, End-of-charge signal
* Thermal protections
* Timer shutoff
* Compact design - latest units are packed into a 10x10x8-inch box (air cooled) or 10x8x7" for liquid-cooled
* User-programmable through a USB cable
We have made design fully open-source and available to all (for non-commercial use). So if you are so inclined, you can make it yourself for less than ~$1,000 all-in (including all the heatsinks, enclosure, etc, etc.).
We have improved the design over the last few months, with beefier PCBs, better drive circuits etc. We also now have an option for 100A output! Finally, a custom enclosure is now an option - professionally machined and powder-coated in awesome black matte finish to show off your charger. As always, you can get more info on the latest specs / build videos / etc at http://www.emotorwerks.com/tech/electronics.
There are over 100 of these units in various conversions out there today.
If you like, we can help you with PCBs, parts kits, assembled / tested boards, and fully assembled units. Again, details are at http://emotorwerks.com/tech/electronics.
I hope that this effort will make EV conversions a bit more affordable to people and we will have a modest contribution to getting more EVs on the roads! Please consider supporting it by letting us help you with building out your units.
As always, we welcome feedback / suggestions / questions.
Thanks,
Valery.
* Timer shutoff
Thanks,
Valery.
