ElectricEd
The history:
My Crystalyte 408R motor started to make a "squeak squeak" about a week ago so last weekend I replaced the bearings, but to no avail. The squeaking continued. When the motor was apart for the bearing replacement, I found that I could not remove the stator due to the magnetic forces holding it in and assumed that this is normal. There was a small amount of debris on the edge of some of the magnets that looked like the varnish that the coils are dipped in. I assumed at the time that this occurred due to the poling that happens during the side cover removal. In the meantime thinking that it must be the nylon washer at the wire entry rubbing on the sidecover, I decided to get some dry-lube for it.
Last night coming home the nature of the squeak changed to a "squea-clack" sound. Damn! It must be a loose magnet.
So, it looks like I need to remove the stator and re-secure at least one magnet.
I'm wondering if there is any special trick for removing the stator and need to know what sort of glue that I should use for re-securing any loose magnets?
