Danny Mayes
Very nice Ratking. Knowing what it takes to get a winding that neat, i can tell you area a patient man
Thud said:I use nomex by default after pulling some shorts on a few motors.
I put a couple strips in your baggie of parts...more than enough to do a motor....i typicly cut a pc 3/8" x 1/2" & bend it into a U shape to wrap the ends of the stator teeth. You can pre-form the nomex on the tip of some needle nose pliers.
Without the nomex,you can pull a short right thru the green epoxy on the stator with thick wire.
Its also very handy to have a multi meter that will sound a tone if yo get a short. Anchor one meter wire to the stator with a magnet & the othe on the magnet wire you are winding with, if you pull a short while winding you'll hear the tone & can add insulation as needed.
Have fun.
What do you want to accomplish? Unload shitty controller that is not maxed of by voltage?Stielz said:Apologies in advance as this is not strictly on topic.. I’m hoping some subscribers to this topic may have information on a SK3 6374 rewind?
I’m currently using two 6374 149kv motors as hub motors on my E-skate. It goes well, just over 50 km/h on 6S lipo. As you can imagine, the current required on such low voltage is high.
I’m looking to tune up the performance a bit, maybe rewind for lower kv and run on higher voltage.
Does anyone know of any 6374 rewinds been done? I’d like to know the kv that results from different winding schemes and number of turns. And also how many turns of X awg is possible to fit around the stator teeth. Any information will be greatly appreciated.
Cheers,
Alex
They normally come in delta, if you figure out each phase strands then go star scheme. The kv will be about /1.7 and benefit of no recirculating current.Stielz said:Yep controller is the limiting factor at the moment. I'm using VESCs which are purpose built for electric skateboards. They are very good but I need to up the voltage to get more power out of them.
