heathyoung
I've gotten hold of a 9C hub motor that has suffered an unfortunate fate - its prior owner drilled cooling holes in it without removing the covers to do so - as such, the windings got drilled (ouch!).
Now, looking at the threads where people have rewound the turnigy RC motors etc, and this thread (http://www.endless-sphere.com/forums/viewtopic.php?f=30&t=25562) which outlines a winding scenario, its got me thinking that a nice heavy winding wire (like 1.5mm or so) would work well for a (very) slow wind motor for the trails - Maybe 14 or 15 turns, for low end RPM, probably wound single or paired like the BMC style geared motors (rather than heaps of little wires, I can see how that will end up).
Not sure where the hall sensors would sit in this winding scheme either, so sensorless is probably a must.
Gives an opportunity for delta/wye configuration as well. Other things like copper fill probably need to be thought through as well. At least the thicker wire holds its shape better.
Any assistance from someone who has attempted this would be great...
