sl33py
Just a little project i had in my head and wanted to share.
Here's the idea - a simple flat protector for the nose and tail that incorporates a super small but bright LED.
I saw the Blitzu "Cyclops" bike lights on Amazon and grabbed the red taillight.
I was thinking a very simple wood or CF plate that mounts on top of your trucks (uses your existing or slightly longer bolts). Imagining a thin 1/4 piece of wood or maybe 3mm CF plate.
Did a quick sketch after measuring how far out from the back bolt heads.
I wish i had some better cardboard or heavy card stock to use as a template... but this was what i had handy for now:
Thinking having it mounted slightly behind the lip underneath will both protect the light if it does hit something, as well as shield it a bit so it's just going forward and down instead of up into my eyes. Adding a small strip of edge trim or something like this:
extra bit of protection.
Mounting the light to the plate... I have the mount it comes with obviously and can sacrifice it, but not 100% certain how to secure it. Was thinking i might finally try to get some practice with 3d printing software - this should be about as simple as it gets - square slot to fit. Add in two bolts through the sides of it to secure below the plate? Simple (in theory).
I might try to figure out a way to make it more of a quick swap connector... Or could hollow out the center channel like an open drop through deck and slide onto the truck from below and re-secure just the bolts to hold it? Tons of ways to do it.
Appreciate input on what you'd do and feel free to make one if you like the idea!! If i get any 3d printing files sorted out i'll share them for anyone else who wants to do this.
What do you all think? 120 lumens front and rear while also giving a bumper?
