thunderstorm80
- Joined
- Mar 29, 2016
- Messages
- 383
Hi,
I love the Phaserunner so much not only because it's small, powerful and fully programmable - It (finally) maps your throttle signal to phase current (and therefore your direct torque output).
Now let's imagine a take-off from stand still scenario, on a 10%+ uphill, using motor power alone. Let's assume we neglect the effects of wind resistance as I am asking about the takeoff performance where the wind force is still negligible.
According to kinematics&dynamics, if I fully throttle and get the maximum programmed maximum torque, then as long I hold it that way - I will have the same acceleration, right? From takeoff, and until wind resistance would start taking it's toll. I also assume we have a battery voltage high enough so we are not back-EMF limited, battery current limited, or any other electronic limitation.
I ask all this because I have the feeling that on such standstill takeoff - the motor first "bog down", and once you are in the 15km/h zone - you can feel a dramatic and much better acceleration, but this doesn't make sense at all!
I think it's because we are so used to driving cars where you use the mechanical gear reduction (or overdrive) all the time, same as we use gear shifting when pedalling:
We are so used that upon startup we get a greater torque output (and acceleration) because of those gear-benefits (and as we up-shift the maximum possible acceleration and torque go down), that when we use a constant DD machine - it feels it "bogs down", while in fact - in such machine the maximum acceleration is always the same across the speed spectrum. (neglecting the effects of wind resistance). Am I correct about this?
This is bugging me in the recent days..
Roy
Roy
