Hey Guys!
I’ve converted a car alternator to be a BLDC. I can confirm that it works fine with a sensorless speed controller. I recently purchased a sensored speed controller, as well as three hall sensors.
I’ve followed the appropriate mathematical formula for hall sensor placement in a BLDC motor, and mounted the sensors accordingly. But the speed controller, after doing a startup test where it turns the motor a little, indicates that there is an issue with the hall sensors.
So my question is, where do I need to place those hall sensors? My gut tells me that hall sensors must be placed differently in an alternator-BLDC to a normal BLDC, due to having a field coil in the rotor, and the claw-shaped nature of the rotor.
Any help would be awesome! Thanks!
Controller: KEB48300X
Hall Sensors: Honeywell SS41
Alternator: 12v, 110A
View attachment 2View attachment 1
