Hi again (Sorry)Yeah they are a more realistic price the one in the diag I found cost a staggering amount.
Thank you. Not sure of the controller spec, like the other 24v folding bike the controller is built into the frame, and TBH I thought I would leave well alone, as they are a real pain to get out, but I would have guessed at 10A, certainly wouldn't expect it to be over 20A
As just making the two packs into one battery appears so simple, (And as I have 4 of these working) I think that will be an easy relatively risk free option, I only really started thinking of // as an afterthought to save swapping batteries for range, and hoped it might give more current on steep hills. but it has turned out to be a lot more complicated than I expected, And even now I think I have worked out how to do it, there are still grey areas, and its a fair bit of work compared with the one battery approach. I'm not too bothered about losing the ability to use them separately, and in fact cannot see why I would want to. And even if I did the same with another two I would still have two separate batteries (both double the mah they original had). I mention that as that's the only way I could see having two separate batteries as an advantage. one could be at home on charge, while I'm out using the other one.
On the heating issue, I was thinking that the nice looking carrier might trap heat (like wrapping the fin batteries all up in a towel), heat that would otherwise normally be naturally conducted to the ally case, then convected away by passing air. So it was this outer case or pillion box that I was thinking of ventilating. Might be overkill, but I have already ordered the controller in the picture, complete with remote probe £2.70 inc post , and I have loads of old pc fans to choose from, and was actually thinking of small one from video graphics card.
As I got the bits I'll do it anyway, peace of mind. Besides in a worse case scenario, if the battery should burst into flames, at least I should get a jet of flame out the back so the bike will look rocket propelled LOL![]()
K
Spent literally hours, trying to find a suitable 36v controller, not given up, but like everything else e-bike related, it's always ends up a bit more problematic than expected.
I did put the controller back in the bike and try with a 2x 12v SLA batteries, and it wasn't too bad, but still felt underpowered.
But that gave me another idea (OH NO! he says)..... LOL. Because its almost useable as a spare bike....... Almost
Well everyone appears to jump straight to 36v from 24v when overvolting, well that's 50%, so you can guess where this is going, As I have now sussed how to build batteries, I thought without modifying the controller or motor, I could go to 28v or even 32v. Try 28 first so build 28v 8S battery pack, well it would come out more than 28v but let's not split hairs. That might well be enough to give the bike that bit more get up and go, and thus make it useable. Found this BMS See Image (2), which will do various configurations (8 cell BMS)
For charging this non standard cell config, I thought I could mod the existing 24v charger (which gives out 29v) to output a bit more to deal with the extra cells. It happens to be in a much bigger plastic box than it needs (so lots of room), So I could fit one of these boosters inside (see photo)
Called "150W DC-DC Boost Converter 10-32V To 12-35V Step Up Voltage Charger Module UK" from the listing).
As the required increase would only be small, even if it's not as good as it claims it should do the trick.
Q1 What do you think, think the controller would take 28v or 32v without mods?
Q2 What about the charger mod, see any problem?
Q3 If nothing else is modified, but an 8S 28v battery is used, that would increase the power, bit more ability to deliver current, and a bit more speed due to motor RPM increase, wouldn't it?
That might be enough to make the bike useable, as a spare, not much work so dont mind from the time point of view trying it, long as it doesn't look like it will burn it out. LOL
Keith
