If ever you are curious what the inside of the Magura MT5e levers look like, here you go the top is the assembled lever. The bottom it’s you can see is mostly taken apart. Had to do this because I shorted out the internal circuit board sensor switch in both levers due to my own fault hooking it up to the wrong side of a relay switch.
So had to order new levers which you can buy separate from the master cylinder.
