Hello, I am new to electric bikes. However, I just started a build using a YZ85 frame. I have purchased the qs138 V3 70h, and the 72530 fardriver controller. My questions is what battery should I go with? From what I have read the 72530 can handle a max of 330amp input. So I was looking at batteries from Amroge with 72v 200amp - 350amp continuous and around 40ah - 50ah. I want to get the most power and range battery that will fit the bike. However, I do not want to purchase a higher amp output battery than the rest of my system (controller and motor) can handle. Any feedback would be greatly appreciated!
below is a links to the battery options I am considering. If you select the battery it will show all 3 options
40AH/ 2880WH/ 250AMP(350AMP PEAK))42AH/ 3024WH/ 350AMP(450AMP PEAK))50AH/ 3600WH/ 300AMP(400AMP PEAK))
www.alibaba.com
Amorge 72v 40ah 250amp 42ah 350amp 50ah 300amp Lithium Battery Pack With Ant Bluetooth Bms - Buy 72v 40ah 250amp 42ah 350amp 50ah 300amp Lithium Battery 72v 40ah 250amp 42ah 350amp 50ah 300amp Lithium Battery Pack With Ant Bluetooth Bms 72v 40ah 250a
Amorge 72v 40ah 250amp 42ah 350amp 50ah 300amp Lithium Battery Pack With Ant Bluetooth Bms - Buy 72v 40ah 250amp 42ah 350amp 50ah 300amp Lithium Battery 72v 40ah 250amp 42ah 350amp 50ah 300amp Lithium Battery Pack With Ant Bluetooth Bms 72v 40ah 250amp 42ah 350amp 50ah 300amp Lithium Battery...
