LG INR21700-M58T?
I googled a couple threads.. here's one that's relevant:
https://budgetlightforum.com/node/82096
Could not find a datasheet for them..
Seems to live up to a ~5700mah capacity according to people testing them, but i cannot find a datasheet on these.
Some people noticed that there were spot welds broken off them etc; my best guess is that they're a newer generation of cell made for a certain manufacturer and haven't really hit public availability yet.
They may be pulls from some device or car.. IE lightly used.
Supposedly these are ~275whr/kg cells it's quite exciting that such things even exist out in the wild. C rate is probably garbage ( ~1C
:lowbatt: ) but it'd be just the ticket for building a >2kw-hr pack with to tour with.. or build a solar storage battery with :mrgreen:
My mistake I meaned discharge Rate. 12.5 Ah: 5.6= 2..
"These batteries are from a canceled car project" I guess those cells won't be easily released again.
The fact is that M58T is quite new cell, but it is likely that more >5000 mAh cells in the 21700 format will appear very soon. Close to the mass market is BAK N21700CD 5300 mAh cell. http://www.bakpower.com/yybk_rlx_en.php
Bumping this thread to see if anyone has played with these.
Found this, supposedly it's a rewrapped LG
Vapcell F58 5800mah 21700
Saggy.. but if you want a high range pack... this would be it @ something like 285whrs/kg
Not once you finish assembling a sack of lipsticks into a pack that can dependably bounce down the road at speed. The more cells you need, the more structure and packaging you need, the more you negate any Wh/kg advantage as you add points of failure.
Seems like a great cell for a dry herb vape or an EDC flashlight. It's about the right size for that job.
First of all for clarification, the cells supplied by Nkon are described on the body as M58 (without T) even though they are listed as M58T.
And secondly here is the cycle life data compared to the Vapcell F60. It can be seen that both models are suitable for practical use. Regarding the F60 results, it is fair to say that these are probably FEB cells, which have a prescribed discharge limit of 2.75 V, whereas I tortured them down to 2.5 V, hence the sudden death at 100% DoD.
Thanks for the information, i'm glad to hear these are being sold in the open market!
I was considering starting a new topic with the clickbait "Do LIB really not suffer from the memory effect?", but I find it disrespectful to the community. The idea is based on the observation of my LIB cycle-life data, where you maybe noticed that cycling at a constant SoC range, lower than 100% produces so-called waves in the data. As it happens, some cells seems do not suffer much from this phenomenon and others have it very visible, which is the case of the LG INR21700 M58 model.
What is considered a memory effect in this case? It is a gradual loss of usable cell capacity during cycling, which is not permanent and can be restored.
What causes it in a real application? Long-term cycling within limited SoC window.
How capacity can be restored? The cell needs to be charged to 100% SoC.
Let's take a look at the M58 cycling data. Here we see a standard cycling life test with 0.5C-chg and 1C-dchg settings with limited SoC window to 4.15V-3.00V (ca 90%) for 49 cycles. This setting is the same for all three samples in the graph. The difference is caused by the nominal capacity test, which is inserted every 50 cycles. For red (M58) and yellow (F60) samples the nominal capacity test cover 100% SoC which is 4.20V-2.50V, but for blue sample (M58) this nominal capacity test is limited to 4.15-3.00V (the same SoC as for cycling) where in the 200th cycle a full 100% SoC cycle 4.20V-2.50V is inserted to demonstrate this phenomenon.
Also, you may have noticed that the blue sample (M58) experiences little capacity recovery even when the nominal capacity test is inserted with the same 4.15-3.00 SoC. This is due to the fact that the nominal discharge rate 0.2C is here used to discharge instead of the test 1C rate. Thus, the cell discharges deeper (to lower OCV voltage) at 0.2C due to the effect of cell IR.
So the conclusion is that some cells like F60 sample does not suffer significantly from the memory effect, but with the M58 you can lose a significant amount of usable energy during the life cycle of the pack thanks to this phenomenon.HE_21700_1C_90%DoD_memory-effect.png
Awesome, look forward to it and thanks for sharing these tests with us!
Thanks to the support of ES community i got access to the samples of serial production M58T model. In few weeks i will start cycle life test. Let's see if there's a significant difference from the M58 sample.
Any news? Thanks for all the data
I need to update HE thread :( . M58T is now at 750cycles, no significant difference between M58, also Samsung 53G1 is finished.
21700 size
+5300 mAh samples comparison
100% DoD (4.20-2.50V) test settings
90% DoD (4.15-3.00V) test settings
Wow thanks so much.
I think the m58T would be ideal for long range packs, where your peak load in amps is 75% of your pack's AH, and your continuous load, in amps, around 50% of the AH.
The vapcells seem to measure out to 5.4AH. Have you measured them?
Yes? ;) Vapcell F60 is the yellow color trend in the previous post if you are interested in cycle life? You can see that it is possible to get out of it almost 6000 mAh even at 1C discharge rate. @CamLight discharged them to only 2.8 V which is actually a proper settings given the FEB datasheet. (Vapcell allows to go down to 2.5V but it significantly affect cycle life)
Was it the case that you were discharging them to 2.5v in your graph, hence you got the suboptimal cycle life?
My capacity tests are to 2.5V (or datasheet low voltage cutoff) but my performance discharges (which are graphed) are down to 2.8V since almost no one runs lower than that in their application and it prevents a lot of confusion.
Just a separate note…it was 5.4Ah delivered at a 5A discharge rate where there’s much more voltage sag than the typical 0.2C rate used by energy cell manufacturers for their cells and often down to 2.5V-2.75V, depending on the cell.
Vapcell said to treat these ”normally” so my capacity tests went down to 2.5V at 1.2A (0.2C) and I got 6065mAh and 6087mAh for the two cells I tested. The cell they are wrapping has a higher low voltage cutoff though, info for those who might drain cells way down in their application.
Yes, I added also cycle life graph with lower DOD (4.15-3.00V) setting and all four competitors shows OK results. The drop in the Samsung 53G1 at 700cycles is due to the fact that I accidentally cycled the previous 50 cycles at 4.20-2.50V.
