Rated Output:300W~900W
Rated Voltage:18V~48V
Axle:10mm
Hole:36
O.L.D.:F 100mm/R 135mm
Freewheels 7-speed.
Weight: Front hub motor-5.95 lbs . Rear hub motor-6.39 lbs
It can be compatible with the controllers that meet the corresponding specifications, or eKITS controller supports from 18V to 48V.
Made in Taiwan.
CE Certification.
Axle:10mm
Hole:36
Freewheels 7-speed.
Made in Taiwan.
CE Certification.
