YoshiMoshi
🔋 Established
I'm building a power tool battery pack. The BMS allows for a maximum continuous discharge current of 35 A. However I can only get about 8 pieces of 10 mm wide by 0.1 mm thick pieces of nickel strips on the holes for the B+ and B- connections in the PCB. I cannot get pieces any more wider in the hole, or stack any more pieces.
Per Metador ampacity tables that are cited on here frequently, 13 pieces of 10 mm wide by 0.1 mm thick has the current carry capacity of over 36 A.
So what is a guy supposed to do? The holes in the PCB are not big enough to carry the rated maximum continuous discharge carrying capacity. Is there some single wire surface mounted connector or something I could use that can withstand 35 A?
Looking online, OEM battery packs usually are 0.3 mm thick for like Kobalt. Interesting.
