I have a 16s4p battery with Eve 50e cells. I'm using it on a Toseven Dmo1, it's 60v 25amps. Pulls max 28amps continuous at 1500w. Issue is my battery keeps going into Over discharge protection, I have a JBD BMS. Idk what's going on. Here are the settings im currently running. It used to be fine until I changed charging current from 3 to 6amps cuz I changed from 2amp to 5 amps charger.
DATA
"app_version": "2.0.2",
"last_updated_data": "2025-06-19, 9:59:29 p.m.",
"platform": "android",
"os_version": 29,
"device_name": "SP17S005P17S60A",
"supported": false
PACK
"charging": "no",
"discharging": "no",
"charge_state": "89%",
"pack_voltage": "63.76 V",
"pack_capacity": "17.9Ah of 20Ah",
"power": "0.0 W",
"charge_toggle_switch": "on",
"discharge_toggle_switch": "off"
ALARMS
"Discharge Overcurrent"
TEMP SENSORS
"Temp. Sensor 1 - 26.9°C",
"Temp. Sensor 2 - 24.0°C",
"Temp. Sensor 3 - 24.0°C"
CELL INFO
Δ: 0.002, min[1]: 3.981, max[3]: 3.983
CELL VOLTAGES
"1 3.981 V [not balancing]",
"2 3.982 V [not balancing]",
"3 3.983 V [not balancing]",
"4 3.983 V [not balancing]",
"5 3.982 V [not balancing]",
"6 3.983 V [not balancing]",
"7 3.982 V [not balancing]",
"8 3.983 V [not balancing]",
"9 3.981 V [not balancing]",
"10 3.981 V [not balancing]",
"11 3.982 V [not balancing]",
"12 3.982 V [not balancing]",
"13 3.982 V [not balancing]",
"14 3.983 V [not balancing]",
"15 3.983 V [not balancing]",
"16 3.982 V [not balancing]"
SESSION VALUES
"max_volts": "63.82 V",
"min_volts": "61.46 V",
"max_charge": "NA",
"max_discharge": "24.3 A",
"max_charge_power": "NA",
"max_discharge_power": "1495.4 W"
BMS INFO
"manufacturer": "DGJBD",
"firmware_version": "4.1",
"manufacture_date": "Mon May 26 2025",
"battery_cycles": 6,
"barcode": ""
EVENT COUNTS
"over_voltage": 1,
"under_voltage": 2,
"charging_low_temp": 91,
"chargin_over_temp": 0,
"charging_over_current": 15,
"discharging_low_temp": 0,
"discharging_over_temp": 0,
"discharging_over_current": 45,
"short_circuit": 46,
"single_cell_over_voltage": 1,
"single_cell_under_voltage": 3
CONFIG
<----GENERAL---->
Number of Cells: 16
<----Capacity Configuration---->
Total Battery Capacity: 20000 mAh
Total Cycle Capacity: 20000 mAh
Cell Full Voltage: 4150 mV
Cell Minimal Voltage: 3000 mV
Cell Self Discharge: 0 %
Cell 100% Cap. Voltage: 4100 mV
Cell 90% Cap. Voltage: 4030 mV
Cell 80% Cap. Voltage: 3960 mV
Cell 70% Cap. Voltage: 3890 mV
Cell 60% Cap. Voltage: 3820 mV
Cell 50% Cap. Voltage: 3750 mV
Cell 40% Cap. Voltage: 3680 mV
Cell 30% Cap. Voltage: 3580 mV
Cell 20% Cap. Voltage: 3450 mV
Cell 10% Cap. Voltage: 3300 mV
<----Balancer Configuration---->
Start Voltage: 3900 mV
Delta to Balance: 15 mV
Balancer Enabled: True
Bal. only when charging: False
<----Function Configuration---->
SW switch circuit enable: True
Display Celsius: True
<----Protections---->
charge over temp
trigger: 45°C 113°F
release: 35°C 95°F
delay: 5 s
charge under temp
trigger: -30°C -22°F
release: -25°C -13°F
delay: 5 s
discharge over temp
trigger: 45°C 113°F
release: 40°C 104°F
delay: 5 s
discharge under temp
delay: 5 s
batt over voltage
trigger: 68000 mV
release: 66400 mV
delay: 2 s
batt under voltage
trigger: 44800 mV
release: 46400 mV
delay: 2 s
cell over voltage
trigger: 4200 mV
release: 4150 mV
delay: 2 s
cell under voltage
trigger: 3000 mV
release: 2950 mV
delay: 2 s
charge over current
trigger: 3000 mA
release: 32 s
delay: 10 s
discharge over current
trigger: -60000 mA
release: 20 s
delay: 20 s
<----Level 2 Protections---->
Level 2 Overcurrent
trigger: 340 A
delay: 8 mS
Level 2 Overvoltage
trigger: 4300 mV
delay: 8 s
Level 2 Undervoltage
trigger: 2500 mV
delay: 1 s
<----Level 3 Protections---->
Level 3 Protections
trigger: 440 A
delay: 70 uS
release: 5 s
<----NTC enable---->
1 | 1 | 1 | 0 | 0 | 0 | 0 | 0
DATA
"os_version": 29,
"supported": false
PACK
"charging": "no",
"power": "0.0 W",
ALARMS
TEMP SENSORS
CELL INFO
CELL VOLTAGES
SESSION VALUES
"max_charge": "NA",
BMS INFO
"barcode": ""
EVENT COUNTS
"over_voltage": 1,
"under_voltage": 2,
CONFIG
<----GENERAL---->
Number of Cells: 16
charge over temp
trigger: 45°C 113°F
release: 35°C 95°F
delay: 5 s
charge under temp
delay: 5 s
discharge over temp
trigger: 45°C 113°F
release: 40°C 104°F
delay: 5 s
delay: 5 s
batt over voltage
trigger: 68000 mV
release: 66400 mV
delay: 2 s
batt under voltage
trigger: 44800 mV
release: 46400 mV
delay: 2 s
cell over voltage
trigger: 4200 mV
release: 4150 mV
delay: 2 s
cell under voltage
trigger: 3000 mV
release: 2950 mV
delay: 2 s
charge over current
trigger: 3000 mA
release: 32 s
delay: 10 s
trigger: -60000 mA
release: 20 s
delay: 20 s
Level 2 Overcurrent
trigger: 340 A
delay: 8 mS
Level 2 Overvoltage
trigger: 4300 mV
delay: 8 s
trigger: 2500 mV
delay: 1 s
Level 3 Protections
trigger: 440 A
delay: 70 uS
release: 5 s
