What’s the best lifepo4 AVAILABLE?
Hummina Shadeeba
🏍️ Giga poster
Sausalito
The big Tesla cylindrical cells are seeming the best energy to weight, no?
When or where are they available in smaller quantities at a reasonable price?
They’re double the energy to weight of the green a123 26650
The 4680 size is nice. I don’t see the Panasonic version available yet of any others that have a decent power output.
For cylindrical cells, what you can easily get are 40135 20Ah cells from the likes of EVE (EVE C40) at about 180-185Wh/kg:
There also exists a nice 165Wh/kg 18650 cell, but I'd advise against building with 18650 cells today for practical reasons:
Similar for 26650 and 26700 respectively:
There do exist even higher energy density prismatic cells that you can buy today, but you then start from a much larger pack :p
Yes, but depending on the size and the use/performance you need, the a123 cells are “power” dense, with a much higher discharge rate (20C continuous, and 50C pulse !) …which i believe is still class leading for LiFePo4….that is their big advantage.
For best energy density (high capacity packs) , the prismatic cells are the winners.
@byke
Messaged me with what seem ideal cells for their power output (70amp peak), energy density (57 to 35 milliwatts per gram compared to a123 26650), and size at 15amp hour and no cells in parallel necessary for me.
I think 75 amps peak. Enough.
A great price! New
You must be reading a different spec sheet to me ?
..the one in the link quotes a capacity of “1,500mAh” and rhe ability to support a 1C continuous discharge witha max pulse discharge of 3C, or 4,500 mA
Something screwed up there !..be very sure what you are ordering
..The other feature of the a123 26650, is their long history of quality product and proven industry use.
It is a pity a123 stopped producing their large format cylindrical cells (32180 ?)
Those are typo's. Should read 15,000 mAh and 45,000 mA
I hope you are correct, but anyway, sloppy data reporting.
And that 45,000 mA is a a “pulse” discharge rate (3C), with a continuous rating of only 1c, 15.0Ah
… someway from that 75 A ?
The sloppy data reporting is by Evlithium hopefully, and not by the manufacturer.
Yea I only saw 75a peak on one site. 3c seems the peak and not enough. Even when I thought was 75a I was a bit disappointed and I had the no-longer-available k2 26650 with 3800mah.
Claimed peak of 28. 3 in parallel would sag and was weak and went back to a123s
Any other lifepo4 that have maybe double the power and half the length?
I haven’t seen data sheets of any of the 4680 size. As it is they’re supposedly a cheap tech but unobtainable except very expensive
There are also A123 Lifepo Pouch cells. I have bought a few 20Ah pouches.
I did test the JK B2A24S20P BMS with them, 500A for 10 seconds and 450A peaks for 20 seconds, 400A for 30 seconds.
They performed very good, now the battery has an easy life in the Kids Kettcar drawing a maximum of 25A.
are the ones still being made in china good? I understand a123 was sold and owned in china now.
I’d get the 12ah version. I didn’t do the math but are they lighter than the a123 cylindrical per watthour?
