72V 21Ah $228
Battery Cell - Brand Cell 18650/21700
The listing doesn't include specific cells, or even tell you if the pack is using 21700 or 18650 cells. If 18650, then that would be at least 120 cells total (20S6P) of 3500mAh cells. The pic implies Samsung 35E cells (the third cell in pink), and includes the Samsung model number, however, it's likely a knock off cell, since it doesn't have Samsung on the label like the legitimate cell. They don't claim to include Samsung cells, they just try to make you think so without saying it. The price is also ridiculous, which is another tip off.
72V 19.2Ah $334
Battery type - 21700 Li-ion Battery Cells
The UPP batteries are passable, although the build quality is so so, and the stock BMS may not perform the balancing function. The listing at least tells you it's using 21700 cells, which are assumed to be generic. To get to 19.2Ah, you would need at least 20S4P or 80 cells (4800mAh). The numbers add up and the price seems to line up as well. I have 2 UPP triangle packs, one generic and one with brand name cells. They both work well, but I don't abuse them.
Can't tell anything about what you get if you order from this place. They have a mix of different controllers and displays, some Sabvoton, some Bafang, and maybe a KT controller. The motor looks like a 9C clone direct drive motor. Can't tell much more. Appears that they just posted a bunch of pics of random parts and just tell you to contact them.
