I've got a used 52v unknown triangle battery pack mounted in a soft case powering a BBSHD mid drive on a Giant Talon frame. My kid took the bike off a big jump because his friend with a Talaria XXX (why a 14 year old in a suburban area has one is beyond me), cracked a rim, and tore the bag off its mounts and walloped the battery quite hard on the down tube. The wrapping is intact and appears undamaged, though the BMS metal plate is dented and the on/off switch on the BMS no longer cuts power to the leads. This pack also is ~3-5 years old (acquired used). The battery did come in a hard case which split a while back.
I tested the output leads at the battery (which was fully charged when he went out), and am only seeing ~28v, though I see 58.8v across the P- and P+.
One hypothesis is that a bus bar may have broken, causing the leads to only pick up voltage from some of parallel packs, or the BMS damaged and impacting output leads.
Is there a safe way to diagnose whether this pack may still be good, or should it just go to the hazardous waste recycler? If I'm looking at a new battery, are there any that would handle some mountain bike activities?
