Hello everyone, I recently bought a MXUS Turbo 3k laced into a 26" rim from the official MXUS alibaba seller and I told the seller I had a hardtail frame with 135mm dropouts. It works great on my current frame aside from a couple alignment issues (even though I'm running torque arms, my dropouts are chewed up after 7 years of use with a 9c motor) and I was thinking of buying a stealth bomber type frame or an Eleek Lite Pro to finally have rear suspension, built-in torque arms, room for a 20s6p or 20s7p battery, etc... Either way, all these frames have much wider dropouts (think 155-170mm). I measured my axle and it came out to between 210mm and 220mm (inaccuracy due to trying to align measuring tape from top down with perspective, etc...)
So I have two questions:
- When buying off of alibaba, does MXUS actually press an axle based on the customer's dropout width or they just have a generic axle made for any size dropouts and mine just happens to fit perfectly because it's the minimum dropout width for that axle?
- Has anyone fit that motor successfully on wider (fatbike or stealth bomber) dropout frames with washers or shims?
