docw009
Minor legend
The frame is a old Raleigh 5 speed with 120 mm dropouts. Actual spacing after all the years is 123mm. Going to run it with a midmotor like the DM02 or TSDZ2.
Want to use a 6 speed freewheel, because I have one, and it's obviously too wide, as the nut/cone are just inside the cavity, A spacer between the nut and the cone bearing on the drive side gives me enough space for the gears to spin w/o hitting the frame. Installing a smaller spacer on the other side allows the wheel
to maintain a 122 mm OLD. Really don't want to spread the dropout 5mm, although it's steel..
Now the rim is off center, but I can dish it over 5 mm. Question is did I miss something obvious. The wheel will be weaker like a hub motor.
