pocketrockets
🧲 New user
- Joined
- May 12, 2020
- Messages
- 2
Hello Guys. New member here and looking for my first ebike primarily for commuting with occasional trails. From my research, I've narrowed down my must-haves to the following:
1. Bafang Ultra Motor - 160nm of torque sounds like fun!
2. Gates Belt Drive - low maintenance
3. Largest battery available
Just wanted to get input on this ebike I found on Alibaba that looks interesting as it looks to check all the boxes for me. Don't think I really need the fat tires so maybe change them to 27.5 x 3 tires. What do you guys think?
https://webike.en.alibaba.com/produ....html?spm=a2700.icbuShop.82.18.3f90743dnNRoNs
1.2020 newest design Bafang Ultra G510 electric fat bike,electric bicycle with 48v 30Ah battery:
Advantage of :2020 newest design 48v 1000w Bafang G510 electric fat bike,electric bicycle with 120km long range:
1. Long range:120-150km after our test.
2. Big torque:Biggest torque is 160N.M and high climbling ability,also have the 5 different level assist.
3. Inner 5 speed change : STURMEY ARCHER Inner 5 Speed Gear Trigger Shift on Left Hand,ride very comfortable
4.Dual battery
ual battery,MORE battery capacity,more range,more FUNNY.
5.Limit speed:Limit the speed to 25km/h,so it can be legal to the law in European.
6.Newest Belt drive,no noisy.
Parameter
Model
MD1000 Belt
Motor
G510 BAFANG motor
Frame
High quality 6061 aluminum alloy 19.5inch
Charing time
5hours
Disc Brake
Tektro E725 4 Piston Hydraulic Disc Brake
Front Fork
RST front fork with good quality
Battery
48v15ah or 48v30ah
Mileage
120KM per charge with 25km/h with pedal
Spoke
front 13g ,rear 13g
Front and rear hub
F150mm /Rear 200mm
Headset
Aluminum Alloy, 700mm Length
Kickstand
Heavy duty aluminum side kickstand
Wheel
26*4.8 Maxxis Tire
Saddle
comfortable sport type
Chain
Belt Chain
Max Speed
55km/h
Detailed Images
G510 Mid Motor:
1000W G510 Mid Motor with 160 NM Torque sersor
Throttle:
Thumb Throttle
Handlebar:
Handlebar
Hydraulic brake system:
4 Piston Hydraulic Disc Brakes
kickstand:
High quality Heavy duty aluminum side kickstand
Battery:
Battery 15AH or Updated 30AH li- battery for choosen (LG cells)
Tires:
26*4.8 Maxxis Tires
Colorful display:
Bikonit Customized, Fixed LCD, Backlit, Adjustable Brightness (Double Tap Info Button, + and - and Info Buttons to Navigate, Hold
+ to Toggle Between Sport Mode and Eco Mode, Hold - to Enter Walk Mode, Hold Light Icon to Toggle Headlight and Backlight
Chain:
Belt Chain,no noisy.
Rear HUb
200mm Hub Spacing,one click quick rerease
Specification:
1.Motor:48V/1000w BAFANG G510 motor
2.PAS: 1:1 intelligent pedal assistant system
3.Battery: 15AH or 30AH li- battery for choosen (LG cells)
4.Charger:48v/2A100-240v AC smart Dpower
5.Front fork: AIR suspension alloy
6.Tyre:26*4.8 Maxxis Tires
7.Front Brake: Tektro725 FRONG 203MM ROTOR
8.Rear Brake: Tektro725 REAR 203mm ROTOR
9.Display: Bafang DPC18 Display
10.Saddle: comfortable sport type
11. Chain: Belt Chain
12. Front hub: 150mm Hub Spacing, 9mm Axle with Quick Release Skewer
13.Rear Hub: 200mm Hub Spacing,one click quick rerease
14. Kickstand: black,26"adjustable rear side, with screw
15. Seat post length : 250 mm
16. Handlebar: Aluminum Alloy, Mid-Rise, Aluminum Alloy, 700mm Length, Low Rise
17. Charing time: 5 hours for one battery , 6 hours for two batteries
18.Range:70kms/ 43.5miles for one Battery,120kms /74.5miles for two batteries
4.Dual battery
Parameter
Model
MD1000 Belt
Motor
G510 BAFANG motor
Frame
Charing time
5hours
Disc Brake
Front Fork
Battery
48v15ah or 48v30ah
Mileage
Spoke
front 13g ,rear 13g
Front and rear hub
F150mm /Rear 200mm
Headset
Kickstand
Wheel
26*4.8 Maxxis Tire
Saddle
Chain
Belt Chain
Max Speed
55km/h
Detailed Images
G510 Mid Motor:
Throttle:
Thumb Throttle
Handlebar:
Handlebar
kickstand:
Battery:
Tires:
26*4.8 Maxxis Tires
Colorful display:
Chain:
Rear HUb
Specification:
