pishta
New-ish here
Silverfish style 48v13Ah drop in battery had a range of about 4 miles. Just low capacity? Took every cell out and tested it on a Liitokala M4 charger that has a capacity test, I'm assuming a timed discharge into a 5ohm 1w load down to ? I reused all the cells that tested higher than 2200mah and had a internal.resistance under 30mOhm just as 70% of the cells showed. The other 30% were shot: 0V, under 2000mah or >30mohm internal resistance. I replaced these with 2500mah <25mOhm cells and welded them all back into the frame with new nickle strips made for this staggered frame. Reused original BMS. Battery shows full on meter and on display. Now the bike goes 2 blocks and shuts down. It will start up again but the controller shows full battery but the battery meter shows 1 bar. I literally tested every cell in this 65 cell battery over the course of getting the strips mailed to me and the welds are good enough to leave nickle on the battery if you try and peel off. What gives? I'm wondering what the cutoff voltage is on the capacity charge cycle. I can use another tester that is more manual and will set the cutoff voltage to 3.4 v and see if that capacity matches the liitokala charger. Only thing I can theorized that the liitokala tests down to some ridiculous 3v or something before stopping the "clock" that shows the capacity? Bummed that this didn't work as it took me 2 weeks to get the staggered nickle strips.
