Ellectrico
1 W
- Joined
- Aug 10, 2019
- Messages
- 53
Please read the full ad and description.
These batteries are coming from a liquidated fleet of Ninebot Max Snc 2.2.3 model with removable batteries.
They are great for powerwalls, portable power banks, bike conversions etc. The size is on the bigger side but so is the capacity and the discharge rage.
The battery has a bms but it is locked by ninebot, so it has to be flashed with instructions and tools you can find online or just remove the native bms and install your own. It takes about 30 minutes at most to do so and it can be done for an additional charge.
The battery has a charging port and a battery meter which is a nice feature.
Full description:
Condition: Lightly used, under 35 cycles ( professionally tested)
Manufacturer: Ninebot
Enclosure: Hard plastic and metal hybrid case.
Cell holders: Sturdy, custom hard plastic cell holders with anti-vibration and insulating gray caulk
Connector: Custom Segway-Ninebot connector
BMS: Custom Ninebot BMS. LOCKED. Needs flashing or re-installment of a new one that's non-proprietary.
Capacity: 27900mAh 1004wh
Voltage: 36v (max voltage 44v min voltage 30v)
Discharge rate: 90 amps, 135 peak (1000w continuous, 1500w peak)
Charge rate: 6 amps
Charge time: 6 hours
Cycle life: ~800-1200 full charge and discharge cycles (gentle use) or 500-800 cycles if used regularly
Amount of cells: 90
Configuration: 10 series 9 parallel
Cell manufacturer: LG
Cell model: lg18650mh1
Cell chemistry: Lithium-ion
Cell capacity: 3200mAh
Cell connection: 0.2mm pure nickel strips
---Weight---
Without enclosure: 11 lb. 4 oz.
With enclosure: 12.5 lb.
---Dimensions---
Without enclosure: 14.5 inch x 4 inch x 2.8 inch
With enclosure: 16.7 inch x 4.7 inch by 3 inch
Battery meter and charge port are installed in the enclosure.
Does not come with a charger.
Full description:
Charge rate: 6 amps
Amount of cells: 90
---Weight---
---Dimensions---
