They’re pretty incredible cells, essentially equal to the JP30 until extreme power levels (I did 100A testing for my Patreon supporters) where one cell has a slight edge. But the 30PL has no manufacturer rating for pulses above its continuous rating.Man, I should have ordered some EVE 30PL samples in my 50PL order![]()
This morning, we conducted tests on our 30PL sample. Its performance under a 60A discharge was much worse than that of JP30. The 30PL could only achieve less than 2000mAh at 60A, while JP30 could reach over 3000mAh.They’re pretty incredible cells, essentially equal to the JP30 until extreme power levels (I did 100A testing for my Patreon supporters) where one cell has a slight edge. But the 30PL has no manufacturer rating for pulses above its continuous rating.
Are you sure there no error in this statement?The 30PL could only achieve less than 2000mAh at 60A, while JP30 could reach over 3000mAh.
Continue discharging (while also providing charging) under the 60A condition until the temperature becomes too high. This indicates that JP30 can fully support a discharge of 60A.Are you sure there no error in this statement?
"JP30 can deliver over 3000mAh at 60A?" - reference capacity, normally measured at 1C or less, delivered at top discharge?
In Mooch's test at 40A JP40 delivered 2,75Ah, Eve30pl with CCC logo somewhat more
Enhanced thermal conductivity and capacity = they're 100% using an aluminium casing instead of nickel plated steel.Does someone knows anything about the Molicel P60C ? We can't see well on their latest linkedin post but I never seen it before. I wonder how it differs from the M65A and P60B.
I also wonder when will we have a decent 6Ah+ cell available to order this year (Vapcell F60 not included since garbage tbh). Many company teased some but not one official test yet.
No one knows anything yet, just what the placard says.Does someone knows anything about the Molicel P60C ?
But...but…no one uses stainless steel.Enhanced thermal conductivity and capacity = they're 100% using an aluminium casing instead of stainless steel.
Oops, thank you for catching my mistake.But...but…no one uses stainless steel.![]()
“Military grade” is a useless marketing term that means nothing.Our engineers conducted a comparison of the military-grade products 30HR and 30PL at 10A and 60A this morning.
Just curious…where did you see that aluminum was being used? Especially since it would have to be thicker (leaving less room for the jellyroll) to equal the strength of a (nickel-plated) steel can.Aluminium is still lighter, 4x more thermally conductive and 6x more electrically conductive, so I am not surprised that Molicel is offering a more difficult to weld, higher performance version of the P60B.
This is completely different from my test results. And I tested the unknown grade LT 19660A version of the EVE JP30P1 too and the same 30PL batch that you show on your web site.This morning, we conducted tests on our 30PL sample. Its performance under a 60A discharge was much worse than that of JP30. The 30PL could only achieve less than 2000mAh at 60A, while JP30 could reach over 3000mAh.
Well, considering they say it has enhanced thermal conductivity (for more safety since thermal gradients are greatly reduced with Al), a more thermally conductive casing would be my first bet as to how they achieved it, and it would explain also why gravimetric energy density increases; aluminium, even with a thicker casing, is so much lighter than steel that it can increase that figure by 5%.Just curious…where did you see that aluminum was being used? Especially since it would have to be thicker (leaving less room for the jellyroll) to equal the strength of a (nickel-plated) steel can.
It would be quite a step for Moli but they might be getting their cans from a different source if true.
Ahhh….thanks. You were 100% sure so I thought you had seen confirmation from Moli or a tester. Yea, it will be interesting to learn all the details about this cell!Well, considering they say it has enhanced thermal conductivity (for more safety since thermal gradients are greatly reduced with Al), a more thermally conductive casing would be my first bet as to how they achieved it
We learned from the internal channels of EVE that the official start of mass production for EVE 30PL is not that imminent. Additionally, regarding the test results of EVE 30PL, I suspect that some of them might not have started mass production due to this reason. In fact, I'm not sure. If you have specific data that you can provide to me, I will inquire with our engineers at an appropriate time.This is completely different from my test results. And I tested the unknown grade LT 19660A version of the EVE JP30P1 too and the same 30PL batch that you show on your web site.
You have the 30PL on pre-order but show the JP30 in stock. Do you have a large stock of JP30?![]()
At present, there is no information about it. I think it is still in the development stage? 6000mAh battery I know have FEB INR21700 6000Does someone knows anything about the Molicel P60C ? We can't see well on their latest linkedin post but I never seen it before. I wonder how it differs from the M65A and P60B.
I also have completely different results. Both cells perform very similar withe 30PL with small better numbers.Are you sure there no error in this statement?
Isn't the FEB 6AH battery the same as the Vapcell F60 ? From what I heard, this battery is not rated for it's 100% DOD (4.2-2.5V) and is not very stable. It can barely handle 13AAt present, there is no information about it. I think it is still in the development stage? 6000mAh battery I know have FEB INR21700 6000
Just curious…what are you referring to when you say the F60 is “garbage”, “not very stable”, and “can barely handle 13A”?Isn't the FEB 6AH battery the same as the Vapcell F60 ? From what I heard, this battery is not rated for it's 100% DOD (4.2-2.5V) and is not very stable. It can barely handle 13A
Hmm…would be interesting indeed. I can get them to about -11°C to -16°C in my freezer.@BatteryMooch When you have the time, do you think you could measure the DC IR for the Molicel P50B and EVE 40PL at -10C? That would certaintly be very interesting to compare about the JP40.
I think those unpleasant words were directed at FEB, not Vapcell. I have heard similar things about FEB production from two sellers. But unlike Vapcell's production, I haven't had a chance to test FEB yet.Just curious…what are you referring to when you say the F60 is “garbage”, “not very stable”, and “can barely handle 13A”?
The FEB 6000mAh 21700 does indeed have a 4.20V to 2.75V range for its cycle life spec but FEB’s discharge graphs for it go down to 2.5V. I couldn’t find a full datasheet. The F60 is rated down to 2.5V too but that’s Vapcell’s rating.
