b0xlife
New here
Ive bypass the BMS on this battery pack and it's working great, but I have a question when I did the BMS bypass I soldered a wire directly from the battery negative straight to the black wire going to the discharge plug without cutting the original black BMS line coming out of the BMS.
It's still charges and works fine, but my question is, will I run into issues because I left the black wire connected coming out of the BMS negative?
Been watching certain YouTube videos I see people cut that wire coming out of the BMS negative (and others who do not cut the wire) and then wire directly to the plug which is what I did except I never cut the wire coming out of the BMS I just wired directly to it and everything works fine.
Should that wire coming out of the BMS negative be cut or is it fine being bypassed this way leaving everything connected with just a line going from the battery negative straight to the ground or negative coming out of the BMS which goes directly to the connection plug?
Or does the negative wire coming out of the BMS need to be cut while leaving my battery negative connection alone?
Battery works well charging it normally through the BMS works fine everything balances out great I was just wondering if leaving the stock negative coming out of the BMS installed as usual and running that wire and soldering directly to that wire coming out causes any issues in the long run that it should be cut coming out of the BMS negative or just leave it alone and leave it how it is.
Does any of this make sense?
