Correction, the AC IR's I reported earlier are wrong, due to not making good contacts to the copper tabs with my IR tester due to melted plastic insulators on the cells. After cleaning up the contacts, the AC IR's of the 2 bad cells now measures 59 and 152 milli ohms respectively. I either over heated these 2 cells during the build or during unsoldering. Most likely the latter because I inspected every cell after I finished soldering the pack and all insulators looked fine back then.I've since R&R'ed the 2 cells in group 9, which had AC IR's of 6 & 14 milli ohms, much higher than the 2 milli ohms when the pack was built 900 miles ago.
