QS motor identification
capitantherockit
New here
The Netherlands
Could someone tell which motor this is?
More technical information is more than welcome..
Printed on the motor:
QSMOTOR-R
DCA QS60/72V2000WJ 251031 6002199
(See also pictures attached)
Motor got 24 pole pairs (counted 48 clicks in a full rotation) 48/2=24
its got NO Temp sensor. (No white wire)
2000W with 35H magnets.
Motor had been sold (on AliExpress) as a V4!?
I've send QSmotor.com an email but had no luck (see answer below) the answer came from siaecosys!
_______________________
Hello Sir,
at present, we cannot determine the exact motor model solely from the appearance images. However, what we can state clearly is that the QS260 V4 must have 16 pole pairs; any motor that does not have 16 pole pairs is definitely not a V4 version. Secondly, if there is no white wire inside the Hall plug, it means the motor does not have a temperature sensor.
If you see this, determining the number of pole pairs is not as simple as counting the cogging steps. Different combinations of stator and 16PP can have anything from 96 to 1248 cogging positions. 96 cogging positions is common.
I have no idea what motor this is though, sorry...
Se vedete questo, determinare il numero di coppie di poli non è semplice come contare i passi di dentatura. Diverse combinazioni di statore e 16PP possono avere da 96 a 1248 posizioni di dentatura. 96 posizioni di dentatura sono comuni.
Non ho idea di che motore si tratti, mi dispiace...
Ciao mxlemming... il tuo osservatore funziona benissimo sulla mia bici!
See this video.... I think you mean something completely different my friend!!
I'm not opening the motor to count the magnets I am pretty sure this is the correct way ! Im new here but that does not mean I dont have any knowledge (Engineer by trade!)
Yes, i see in this video you're shorting the wires so in that case it's a good way to find the number of poles. Definitely works.
