anerickso123
New here
Ive been attempting to upgrade the battery and motor on this 36v ATV. Everything was working at first. Then it failed to turn on. I opened up the controller View attachment IMG_0696.jpeg
and found it had a burnt plastic smell inside. Hoping it get some guidance on what to do differently to prevent this same result.
This is what I did: I cut the wires on the controller and connected it to the t-plug adapter that came with the battery using wago connectors. I then plugged in a new motor along with the throttle into the controller and everything was working. The throttle was turning the motor. I then worked to remove the old motor and during the process I may have damaged the wires on the throttle that connect to the controller. Once I got the new motor installed, I reconnected everything and nothing was turning on. It seemed to me that the controller was dead, and that does seem to be the case based on the smell.
I’m gonna buy the same controller as it’s the only one I can find with reverse, three speed controller, and 36v 800w. But what should I do differently? I’m thinking of using XT60 adapters instead and trying to crimp the wires together instead of using wago. I’m also curious if the damaged throttle could have been the culprit not so much the battery connection itself. Any advice would be very much appreciated as I’m close to throwing in the towel on this upgrade. Thanks.
and found it had a burnt plastic smell inside. Hoping it get some guidance on what to do differently to prevent this same result.This is what I did: I cut the wires on the controller and connected it to the t-plug adapter that came with the battery using wago connectors. I then plugged in a new motor along with the throttle into the controller and everything was working. The throttle was turning the motor. I then worked to remove the old motor and during the process I may have damaged the wires on the throttle that connect to the controller. Once I got the new motor installed, I reconnected everything and nothing was turning on. It seemed to me that the controller was dead, and that does seem to be the case based on the smell.
