Moretorque
Regular
Using a 48 V solar panel to charge a 48 V battery directly how simple could you make this. My battery charges at 2 amps so a 400 watt solar panel directly would burn this up correct? Just curious and thanks.
I have hooked this directly to a constant current constant voltage booster
I've also experimented with this, and this happens because the simple boost converter doesn't have the same "smarts" that a charge controller has, to ramp down current demand in decreased sunlight, and ramp it back up.but if I shadow the panel even slightly, briefly, then the max output falls to 52ish watts.
At that point I need to lower the current control trimpot to below this 52 ish watts,
Solar Ebike Systems - Getting Advanced - ResourcesSo what do you think? can you build something that simple that will work well to be packed on the bike?
This may not be what you are interested in, but it does exist. I have one, and I have used it to charge my nominal 48V 960Wh battery from Cap Rouge:Just curious and thanks.
I could rig something up, but it would not be kosher. Key is using my 0-60 minute mechanical timer. would need a fuse and a resistor or maybe diodes. would charge outside and watch it the first few charges. it would be like science class, an experiment or in an emergency. the timer keeps it from overcharging.Using a 48 V solar panel to charge a 48 V battery directly how simple could you make this. My battery charges at 2 amps so a 400 watt solar panel directly would burn this up correct? Just curious and thanks.
So basically get a nice small Victron charge controller like a 75 15 ?
The 75-15 Victron controller is for 24V nominal systems, not 48V. It'd be foolish to employ a 'booster' when you can simply use a Victron 100-20 instead (for 48V systems).If your battery is 48v, I assume you want to charge it to 54.? volts. Using a Victron 75/15, you would need 60-70v pv input. If your panel is truly 48v then you need to boost it to > 54v to charge your battery. Feeding 48v to a 48v nominal battery will not charge it. If you want current to flow it has to be higher. A boost MPPT controller will take care of that.
I was gonna try putting a 5s1p li-ion between sub 21VOC panel and cccv booster, to keep input voltage from tanking when a shadow briefly passes over the sub 21ocv 12v nominal panel while cccv booster was trying to maintain constant amperage output.I've also experimented with this, and this happens because the simple boost converter doesn't have the same "smarts" that a charge controller has, to ramp down current demand in decreased sunlight, and ramp it back up.
I've never needed a BMS, just a voltmeter on the handlebars. when a cell gets out of balance it will show a 3 volt drop alerting me to balance. this only happens on packs over 10 yrs old. I charge with an old 36v SLA charger all the time on my 40v pack, and have 2 old 24v car chargers wired in series for my 14s10p 2/4/7 amp rates. all use the timer, and I only shoot for 80-85% charge. another clue it needs to be balanced is that the final voltage is higher than history.Not to be a downer, but won't the battery BMS mess with the unregulated charging input. I know the BMS's on my batteries dont even like other chargers of the same volt class and current. I had to color code them.
I have Two inline 'Ideal Diodes' I can easily use on either end of CCCV booster, or both.sternwake
if you use a diode to prevent backflow, you should be able to have it charge after a cloud or sunrise after night.
I'm not too optimistic on that. I was thinking direct to pack.I have Two inline 'Ideal Diodes' I can easily use on either end of CCCV booster, or both.
I'll try them and report back.
Sun is down, so do not hold breath.
