Pajda
🚴♂️ Mega poster
Btw. I am not sure if BAK 65E and Molicel M65A are tabless?
May have jumped the gun on this one, edited the post. Good catch!Btw. I am not sure if BAK 65E and Molicel M65A are tabless?
The 60P?Have you tested Linkdata P60B? Looks not bad with max 60A current and 6000mAh![]()
Under what conditions? Charge/discharge, current, and what pulse duration?DCIR is 11.5mOhm
Discharge, 3A, 10s pulse, 25*C.Under what conditions? Charge/discharge, current, and what pulse duration?
Attatched a batch of 40 units of Linkdata 60P, for now just measured AC IR and mass, check it:Have you tested Linkdata P60B? Looks not bad with max 60A current and 6000mAh![]()
If you want some special test I could do it, for now I will test 0.2C capacity, qOCV, 30A CC discharge till 2,6V...
Huh, are they going under or what? They're supposed to be at AABC Europe next week.Uh, Reliance's website is not available anymore
It points straight to a 404.
This isn't good...
Ah, it seems they may have a new website that hasn't really been indexed yet.Huh, are they going under or what? They're supposed to be at AABC Europe next week.
E. Website seems fine to me? It's this one right
My Patreon supporters saw the prelim test results a while ago but the full test report for the 60P goes public this week.This way, we can compare it with other cells that Mooch has tested like the 50XG
Thanks for the data. Could you do a discharge test and temperature graph according to different current values (for exemple 15A, 20A, 25, 30, 35, 40) down to 2.5V ?
Oh my, I didn't notice, but this website has been heavily made with LLMs, I can tell.Huh, are they going under or what? They're supposed to be at AABC Europe next week.
Does someone has the datasheet of the Linkdata 60P ? I'm struggling to find it and find their website other than the Alibaba listings
I much preferred the old website![]()
It's been available for a while on the official Murata website:Yeah it's so laggy
Btw I see you are good with datasheets, are there any chances you can find a Murata VX40 datasheet![]()
