Long time no visit, new project, tips andinfo on motor needed.
dutchlincoln
⚡ Regular
Hello,
Its been a while since i was here with Escooters etcetera, but now i'm working on a new project.
I bought 2 stand up e-scooters (kickbike fatmax) and want to upgrade these.
Dropout width: 135mm, no chain needed, so front motor will do.
Rim size 20x4" needed (fat tire)
Preferred a lot of torque, and a topspeed of 18-19mph. (this is due to regulation and insurance.)
I came across a topicof a leapmotor 1500w motor, but its a tad old topic.
I read about .35mm lamination, 4T 5T 6T etcetera.
Is this still a good candidate? or are there better options to be had nowadays?
What bothers me at leapmotors, is the spokes being straight spoked, not crossed, wich is quite unusual? (and less strong?)
Bafang has geared hub motors, and i thought this might be better suited as it delivers less RPM and more torque, just like i need. Pricey though, and i think less strong, more moving parts.
About the 4T 5T 6T, since i need less speed and more torque, would it be wise to go for the 6T?
Any recommended controllers? i prefer a controller behind the tube battery, like polly and Hilong, but maybe there are better options?
A lot of questions, i know.
Relocating to relevant topict is also highly appreciated, thank you.
Welcome back!
Leafmotor is still good, but surpassed by the Grin All Axle in power density, as far as DD motors go. But there is a big cost difference.
What kind of top speeds do you need and what's your terrain like? ( flat? steep? rollercoaster? )
If you don't have substantial hills, you might get away with a geared motor. If your power requirements are modest, i'd go with a Shengyi SX2 since it's the current power density/efficiency champ in the ~750w rated range. Bafang has some nice stuff today at higher power levels.
Hi there,
Intention is steep, hilly and forest terrain.
Top speed 18 - 19 Mph (30Kmh) Legally limited to 25kmh, and 30 is allowed. Beyond its a big fine or scrapped bike. I can do this with programming the controller, as long as its not possible.to easy set it different mode when you drive. Programming with PC at home is fine though. I rather have the limit in the motor, resulting in more torque instead, as it running closer and more efficient when its running at its top speed.
I will take a look at the grin all axle, thanks.
The bafang i looked at, were mostly 170-190mm, whereas i need 135mm
Im looking at the leafmotor due the attractive pricetag. Wheb i take a 6 turn, i understand it will make 336RPM, giving me a speed of 32KM/H (approx 20MPH)
How precice is this value under load?
is it safe to say that i loose about 10 percent under load, or will it just keep 336 rpm @ 1500W? (calculations by google state approx 200-250watts are needed to maintain 20mph).
i assume the motor is at its best efficiency then, feeding it with 48 Volts battery? 3T will draw less amps as a 4 5 or 6T i presume?
Looks like a fun ride. There's no fear of speed cameras in the forest, surely you'll want a hidden off-road mode. 25km/h will substantially reduce the fun. With those big fat tires you'll be able to tackle most terrain a lot quicker.
The long old leaf motor thread you found is the bible for those motors. Everything you could want to know will be covered.
You're better off with motor in the rear than the front, for various compelling reasons, including torque and traction.
For a battery <10kg, I think backpack is the way to go for kick bikes. Camelbak bags make a good starting point, nice light strong comfortable harness system, but you can use obviously use whatever you have laying around. Bag makes a big difference to the comfort though, and keeping the weight up high I find preferable, which the camelbak style hydration bags work well for.. You can test ride with bricks or beer in it to see how you'll get along with the weight on your back.
Hi, thanks for the reply.
Im looking for front wheel motors due the space of 135mm in the rear. (naturally it will be in the rear wheel, it is right now as well.) it currently has a 36 volts onframe battery with integrated hailong/polly controller.
Actually i prefer to keep it like that, just want to replace it for 48 volt and having more power less current. There are 22 fet models that would fit there, saves me a separate controller to install somewhere.
About the speed:
Its not that i'm afraid of camera's, but cops here dont like these kind of equipment and regular put you on a testbench. When it exeeds 30km/h you will lose the bike and they swap it for a fat fine. Not insured as well if something happens. Dont want to risk that.
I just figured with a lot of torque the woods will be superb going 30 through.
Theres a rental company in the netherlands that has the 500W models and they give you a track computer as well to ride several forest trackt and its magnificent. Done it a few times now and i love it. Just need a litttttle bit more torque, which is why i was aiming at 1000W, but the leafmotor will do great with 1500W. Only downside is that with increased power, the speed increases as well and i dont want that. Unless its a programmable controller (not by display, thats illegal, must be by computer) that limits the legal speed, its no problem then.
ps. Its not that important if i have 5 or 10% less efficiency. i plan a dual battery anyway, and swap them if one is empty, to return home again. Also thinking about installing a frame battery and a slide-in battery at the rear as a return-home backup...
If we're using a direct drive motor, and you're going up hills, efficiency matters enormously so the motor survives.
The 22" effective wheel size on your vehicle ensures it won't be too stressed when climbing.
At the low speeds you want to run, you not really using the capabilities of this motor.
Motor Simulator - Web Tools - Resources
Efficiency goes up as you add more voltage and go higher speed. A DD hub is much less efficient at low RPM.
A geared motor makes sense for this use case, but if it's offroad, you should know that this beats up the gears inside. So you want a motor you know you can get replacement gears for.
Geared motors shed heat poorly. During extended hill climbing, they are great at dishing out the power... until they overheat much faster than a DD 😅
However if you use a pair of smaller geared motors, splitting the load between them works out really well:
You probably want a motor with a higher power rating where most of your weight is, if the split isn't 50/50.
You mainly want a stronger motor than this so that it has stronger gears to take the offroad bashing better.
Yes, i actually stepped away from the geared motors.
Now, i've been reading and youtubing further around grin motors, and i think i'm in love...
The 45Max motor, providing very wide magnets of 45mm, ensuring heaps of torque are really great. When configured in 6T, it has a power of 7.2rpm/volt, so giving me a RPM of 345 with a full battery. 345Rpm gives 38KM/h as a speed. A bit too much, but i can program it to 30Km/h, being 20% below max. speed. Positive side is that it will remain this speed when battery gets drained.
Now, i read about their baserunner controllers, and this is exactly what i'm looking for actually. Combining it with a very nice color display, and a regen capable throttle, bike lights output, its really fantastic, exactly fits my needs actually.
It has a 12V output on which i can connect my motorcycle navigation on to be powered as well. Its hidden behind the battery mount having less cable clutter and disgarding extra controller housing, it really checks all boxes.
If they can provide it well spoked into a rim, it would be a really complete drop-in-place set.
Whats your opinion on this combo in my setup?
Can someone explain?
I have put in the data in the motor calculator for the standard version of the slow 45max motor with statorade vs the std version.
The version with statorade runs cooler, but uses more power and gives less range and efficiency???
A lower speed of 6-7km/h degrades range with 80% ???
Been playing with the calculator, but the results are stunning tbh.
Is it possible to limit current, or do something different when not running max. rpm?
You said you were trying to compare different motor windings, but I see different controllers selected:
Maybe you should only vary one thing at a time?
Personally, I have a Baserunner controller on a fat bike and consider it very underpowered. Max amps and max voltage are very limited. I like to go 30mph, though. If your speed limitation is true, I suppose it might be enough.
yeah i saw the difference. Accidentally selected the wron controller, but the difference is merely the same when i select the baserunner on both.
Im just stunned about the power decrease when running 7kph slower.
So, when i run it at 32kph, i get 56km of travel, and when i run it 25kph, i get only 13km out of it? Looks wrong to me?
correct picture:
Same on 36 volts...
It means that i actually need to lower the voltage to get what i need?
i'd suppose the controller would manage this, but apparently it doesnt..?
You're receiving good advice. Amd spending time with Grin's calculator. You can't spend too much, it's a brilliant tool.
Kick bikes fall under scooter regulations, and there's no power limits on them, so you can use any motor you want and give it hell.
Compare the torque curves for yourself, but my experience with scooters is 30 battery amps with a light vehicle and rider, and a lot of gear reduction, can be exciting enough. Enough, not scary, but guaranteed big smiles. With a direct drive hub motor you'll want a lot more, and therefore need a very capable battery if you choose that option.
There's no such thing as too much power. That's what a throttle's for, to regulate it to match the conditions.
Don't stress about top speed and getting on the wrong side of the law. That's easily overcome with controller programming.
Thanks,
I think this will be huge fun indeed.
no need to push the ultimate limits.
If i want to go insane fast with heaps and heaps of torque, i put my helmet on and awake my Rocket-III :)
But.... When i reduce topspeed with programming... do i go to the highly inefficient part of the lines then?
The power limit i know, i thought the official limit was 4000 watts, but the main thing they look for, is topspeed. It is not allowed above 25kph. (in the registration theres no mention of power as well, only construction speed of the verhicle.) The reason i'm a bit pecky on this, is when they pick you at 30 plus, you can lose your driverslicense, and i wont be riding my car and motorbikes as well... Dont want to risk that. But enough on that, just for clarification.
The way i want to proceed now, is to buy a baserunner L10 and a batterybase that fit my current batteries, and connect it with my current motor to see what i can push out of it. If it burns, it was already too weak anyway.. :)
I want to go with the supercable and center display, double twist grip etc.
Only thing i havn't figured yet, is how to connect a braking signal when i install hydraulic brakes... They all seem to have contacts and halls for mechanical brakes.
Final destination is the Max45 all axle.. :)
Just ordered 4 batteries 48V 15A (2 bikes) inclusing 4 brackets and 2 chargers.
I want to mount 2 battery sets to the frame. How would one suggest to switch between both? I dont want to parallel them, as i want one to be the backup for the first. So, on a trip use battery one, and for trip return, use second battery. Charge both when home.
I could make a mechanical switch between them, but i was more looking for a fancy way to be able to read both and swich electronically.
Any suggestions?
ok, but thats a little more tricky, as they always need to have the same charge. If you switch one later on than the other, one will feed the other and high currents can flow.
When parallel, actually should delete both switches and make one central 9double pole) switch. A bit harder to create, but not undoable.
correct picture:
It is because you are running full throttle. At 32kph you are just making enough power to keep that speed as you are running out of voltage. At 25kpm you are at full power. Lower the throttle to get the speed you want to compare.
Aaaahhhhhh.... You mean set the trhottle in such a way (eg 60%, 80%,) so you will reach the desired 25kph?!
Will try, thanks.
I just coulndt figure why it would use so much power with a lower throttle, but i realise now i didnt do that. thanks!
Whahahaha, i just played with the calculator, starting at 80%. No change. 60%... no change. huh?
When declining to 14% !! no change.
To get to 25kph instead of 32 (at 48 volts) i need to go down to 11.5%...
Does this mean the setup is way way overtorqued, or... ?
i mean: to reach goal at just 11.5% is a tad strange...
Do i misinterpretate, or?
Does this mean this setup will pull the handle out of your hand when even thinking about touching the gas?
correct picture:
Have you been using the simulator a while? In order to ride slower, you usually reduce the throttle, but you are using full throttle and reducing speed at the same time, which will give you odd results. If you check the auto box, and reduce the speed, you will see range go way up instead of down from 56km to 74km, rather than 56km to 13km. I'll admit, I don't know what you're trying to represent in the simulator, so ignore this if it's not what you're trying to do.
PS. When not checking the auto box, the results are good for checking torque and acceleration at a given speed at full throttle. This is valuable information to understand how much roll on acceleration you may have when you are already going a certain speed and then hit full throttle to accelerate, or climb a steep hill, etc., so the no-auto setting is helpful for comparing single points along the curve for expected performance at that speed.
yeah, im starting to figure this out now indeed, like you say. I was just shifting the black topspeed bar instead of the throttle.
But, is it heavily overtorqued and unridable when i reach top speed at 14% ?
Most programmable controllers have a soft start feature, if not complete control of the throttle ramping. So if you prefer soft start over immediate responsiveness, it's pretty easy to set something on a CycleAnalyst, for example, to limit the amount of throttle it will actually increase per second, etc..
