MitchNotMitchell
I'm building a power assisted trailer - lots going on and problems I'll have to solve for sure - but at the moment I'm looking at 1"/25mm square tube aluminum to build a frame for the wheels - they will be based on 27.5" laced grin all-axel front hub motors.
I haven't done CAD or milling in a couple decades. But I understand the basics / can read plans so I'm hoping to find either suitable parts or something easy to modify OR someone who can point me in the right direction (will pay for help). I don't want to get so mired in construction challenges that I can't worry about programming or building my body or riding lol
My thought was to go with 15mm through axels. But I have to allow for torque arm installation, and either some sort of through axel nuts with drop outs etc.
With just the 1" frame, I could drill a 15mm hole, and a larger hole on the outside edge to insert and bolt the through axel in. But I also have to deal with the brake caliper mounts. Grin has a variety of those available however most are for special purpose bikes and quite expensive and won't accommodate the square tube frame. Link below.
I've also thought of milling my own (I'd send it out / contract it) drop out adapters from 5mm flat stock - I'd be able to allow for mounting their DIY torque arm, and also include holes to mount a caliper on it.
Here's a couple sketches. Details below - I appreciate any and all feedback - including people questioning my sanity as long as they have reasons for it
If anyone has experience or ability to suggest a place to get torquearms / brake mounts milled if custom ones are required or anything else... thank you!
Front wheel diagrams:
Torque arm adapters:
Where in my sketches I've shown a straight tube structure (specifically in the case of the long ladder frame), I believe it might need to be built into a beam with angular bracing - but I didn't want my drawings too complex:
The trailer is intended to carry its own weight, plus about 400-500 pounds of total payload. Likely only about 300 typically.
Here goes:
* Ladder frame from 1" square tube approx 8' x 2'
* The front part of this frame will need sheeting on the front / bottom as part mud guard / part support. There are 4 batteries going in that area (approximately 100 pounds). Sheeting the entire bottom with something like diamond plate is something I'm considering as it would enable me to use the underboay for long cargo storage (poles, canopy, etc.)
* 2-3 bolt plates which will be installed in the trailer body (not illustrated here)/ leaving bolts protruding to mount to base. They will be blind in the trailer body hence the plate. Matching holes in the ladder frame required.
* A second small frame approx 32" x 36" which would hold two more wheels in "drop outs" or a through axels. By each of these would need to be an accurately placed block for a disc caliper for brakes.
* The second frame would be connected to the first with scooter shocks (4) arranged in a trapezoidal form. This will allow for multi direction flex (vertical as well as twisting to deal with rough road, pot holes, etc.
Thanks for taking the time to read!
Cheers
Mitch
Here goes:
Cheers
Mitch
