John in CR said:
Does the "auto" mode include auto startup after input power recovers after clouds pass by? The need for manual restarts made me dismiss RC chargers as potential charge controllers, since I lack the electronics skills to modify their switching to an "auto on".
John
John,
I don't know LOL
but the controller will be right in front of my face so I'm sure to find out :lol:
The 1010B continues to be "out of stock" so I've yet to actually place my inquisitive hands on a real one
Kingfish said:
I can’t believe we are entertaining solar again as an energy resource for long-distance. ....
etc
"we" are not entertaining solar
I, however, am.
And in fact have been testing various panels and charge methods for several months.
Having extensive experience with solar and intimately knowing where I wanna travel, not only is this doable for me, but less expensive than purchasing the extra batteries.
However, the panels and mounts should be about 5 kilos heavier than the equivalent batteries I would need to travel ~80-100 miles, round trip
Why solar is likely to work for me...
First off I don't need to travel if the weather forecast sucks (important point)
I want to ride specific routes, where I already know the roads. I'm not interested in traveling cross-country. I'm only interested in day trips to adjacent cities.
I don't remotely travel fast and my power use at the speeds I travel hovers around 100w average -i am hardly representative of the average board member here because I've no interest in traveling faster than about 10 mph (unlike , uhm, John LOL)
My trike uses a dual-motor setup quite different than other dual-motor users. One motor is
only powered up for hills the main motor struggles with (think about it)
I've been using this setup on my current trike for several months and it works as I intended it to, taking a huge load off the main motor/battery and allowing me to power up hills with moderate pedaling on grades approaching 15% (and I mean *very* moderate, as in equivalent to pedaling on a flat surface without the electric assist.)
The bike lanes over most the routes I ride average 6' wide (10 feet wide for long stretches) Folding out both panels will have one straddling over the right hand side of the road (total ~6' wide) which I don't foresee a problem with, but we'll see.
I'm building the panels myself, using ultra light-weight construction methods. The cells (as currently designed) are to be mounted unprotected and will require constant attention to weather changes. The panels will fold on top of each other for protection... conversely one panel folds under the other if space is a bit narrow (and switched off)
The diy panels will be:
Two panels of ~ 6.5'x3' mounting 75 6"x6" cells each (150 cells total wired for 15v@ 22A for a peak of ~330w but I expect to only get half that on a sunny day at my latitude.
My 200w of panels have generated close to their peak performance here, but I can adjust their angle to the sun. On the trike I'd rather have the panels horizontal, with anticipated loss of power to avoid the worst complications of crosswinds.
These panels will be mounted overhead a custom built, rather funny looking tricycle.
and lastly
I'm building this,
because I can.
